Think I put differential fluid in wrong hole...
Old Dec 5, 2004 | 10:07 PM
Kurt Crosbie's Avatar
The first bottle I put into the hold on top of the diff housing. It had a little cap on it that I just took out. There was about a 1/4" hole there. I figured that was the one. Then I noticed oil started coming back out before I even put the first bottle in.
So I took off the fill hole bolt on the front off the diff, and to no surprise, nothing came out. So I put the other bottle and the additive in this hold.
My question is, where did the oil I put into the upper hole go?
Old Dec 5, 2004 | 10:37 PM
a walker's Avatar
Re: Think I put differential fluid in wrong hole...
On the passenger side of the rear end housing, toward the top, there is a plug. You use a 3/8" drive ratchet (no socket, just the ratchet) to remove the plug, and pour it in there. Once it oozes back out, it's full.
I can't picture where you put it in at.
Old Dec 5, 2004 | 10:47 PM
I put it in about 2 inches above that.
Z95m6's Avatar
if i had to guess you put it in the breather hole. No big deal it will make its way down to the center section.
PCLZ28
Dec 24, 2015 05:19 PM
WildRidez
Feb 23, 2015 07:24 PM
737drivr
Feb 20, 2015 11:54 AM
David Dorris
Jan 17, 2015 08:10 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
