brake rotors grinding bad on 12 bolt!
Old Dec 4, 2004 | 05:51 PM
ftransam1's Avatar
Can't figure this one out. I bought a used 12 bolt from a friend that has less than 100 miles on it. Awesome deal and he had no problems with it. I installed it and my brake rotors are pushed against the inside of the caliper. They just grind on there. There is no spacer installed on the rear end either. I ground down the calipers a bit to stop them from rubbing but they still do a little. Anyone else have this problem and know how to fix it???
Ryan
Old Dec 5, 2004 | 10:48 PM
Z95m6's Avatar
Re: brake rotors grinding bad on 12 bolt!
Is the rear end out of an LS1? they are diff, than LT1's. LS1 axles are longer. Maybe that helps you out.
Old Dec 6, 2004 | 01:12 AM
ftransam1's Avatar
No, it was out of an lt1. I helped him remove it too. From what I understand now, I should have shims placed behind the rotors to push them away from the caliper a bit.
Old Dec 6, 2004 | 01:15 AM
Z95m6's Avatar
So its going from an LT1 to another LT1? correct?
maybe2fast
Mar 16, 2015 09:45 AM
dale3in98
Feb 14, 2015 12:18 PM
ddr698
Jan 9, 2015 10:05 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
