Twin Turbo LS1
Old Oct 5, 2002 | 09:24 PM
HellSpawn T/A's Avatar
Question Twin Turbo LS1
I am thinking of buying a 98 TA and putting a TT kit on it. With 315 Nitto's on the back, what am i looking at running in the 1/4?
Old Oct 5, 2002 | 10:24 PM
6speedZ28's Avatar
Well your 1/4 mile time should be PRETTY DAMN QUICK@PRETTY ****EN FAST , if I wasn't on a college budget I would do it to the SS.
Old Oct 6, 2002 | 10:12 AM
supersp0rt's Avatar
depending on boost, mid-ish 11's
Old Oct 6, 2002 | 10:24 AM
Capn Pete's Avatar
Question
Where can you buy TT kits?? Who builds them?? And (ball-park) how much??
Old Oct 6, 2002 | 12:01 PM
BISHOP's Avatar
Have fun trying to find a complete TT kit since Incon was the only one out and they are out of buissnes.
Old Oct 6, 2002 | 12:21 PM
supersp0rt's Avatar
there is a guy on ls1 that had a kit built from chargedair.com. he says that the kit is available and is a TT kit and retails for about $6200. i emailed the site about a week ago inquiring about this kit, but have received no reply yet.
Old Oct 6, 2002 | 01:34 PM
maddboost's Avatar
Well first of all why do you want a twin turbo kit? Twin turbo kits are generally designed to give you the same boost as a big single turbo kit but with quicker spool up. But if 1/4 performace is your goal I would go with a LS1 motorsports single turbo kit. Its a proven turbo kit and they offer installation. Also spool up on V8s isnt as big of a problem because turbos are driven by exhaust gas and larger engines put of more exhaust gas. Also the advantage of having a single turbo kit is you can keep it below boost around town to save on gas but have the power when you lean on it.
Old Oct 6, 2002 | 03:05 PM
WDW MKR's Avatar
Question
I would really like to know more about the CAS kit. Seems like there is much talk about new kits from CAS and Banks, but no one ever has details. Tony build high quality products at CAS. Their intercoolers for GN's are top notch, and perform flawlessly. I was very happy with mine. The customer service can be pretty slow, but the end result is usually worth it. Anyone know if this kit is actually for sale?!
Old Oct 6, 2002 | 04:19 PM
JackZ.Twenty8's Avatar
Incon went out of business??? Man that sucks.. I thought that was such a great setup, from what I had read on the different boards..
Old Oct 6, 2002 | 07:08 PM
zlightning's Avatar
Why would having 2 turbos stop you from lowering boost? still have the waste gate still have everything that the single does just some extra parts. [
Old Oct 6, 2002 | 08:12 PM
95TealLT1's Avatar
http://www.turbotechnologyinc.com/
This place has them for around $5,000. Not including labor.
You might also need tranny work, heavy duty rear end, sub frame connectors and some real sticky tires.
Old Oct 6, 2002 | 10:25 PM
supersp0rt's Avatar
a bit behind arent you?
anyways, there is a guy on ls1.com that has the prototype kit on his car. the CAS kit that is...best bet is going to be to call them and find out. their website is about as informative as the crack of my ***, so you get the picture.
Old Oct 7, 2002 | 12:33 PM
Supersp0rt where do you live?
Old Oct 7, 2002 | 12:37 PM
BlackHawk T/A's Avatar
There is nothing a Twin Turbo system can do that a Single Turbo can't. Professional drag racers run single systems and they have their reasons. In my opinion it is not worth the $$$.
Old Oct 7, 2002 | 07:11 PM
Big Red Jim's Avatar
In most serious racing cases, it's because twins are outlawed, ie: NMRA.
