wheel hop problem
Old Nov 25, 2004 | 02:29 AM
Camaro350z28's Avatar
wheel hop problem
Tryin to figure out why i have a wheel hop problem... im curious.. if you hit on your torque arm with your hand.. does it rattle or is it a solid hit like if you were hittin a frame? thanks
oh, also on the torque arm.. about right in the middle of it there is like two nut type things, thread holes where it looks like something could be threaded into it? i have nothin in those holes am i missing somethin?
Old Nov 25, 2004 | 04:25 AM
AL SS590 M6's Avatar
Moderator
Re: wheel hop problem
That's the carrier bearing mounts for a 2 peice driveshaft used on V-6 cars. Not used on V-8 cars.
And your torque arm shouldn't rattle when you tap it. Somethings loose or the torque arm to tranny mount is shot.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
