can the stock 12 disc be mounted on the trunk wall?
Old Nov 22, 2004 | 12:47 AM
D James's Avatar
The place I'm talking about is the back wall where you would find the rear taillights, the place that is usually used for amps. It looks like there would be enough room for it to fit and still retain the T-tops back there. Has anyone done this? I don't want to mount it on the other side cause that means I wuld have to cut the plastic to make it fit and move the jack.
Old Nov 22, 2004 | 04:13 AM
LS1 RULZ's Avatar
Re: can the stock 12 disc be mounted on the trunk wall?
The stock changer doesn't have an adjustable suspension. That means it has to be mounted horizontally. If you want to mount it vertically you have to get a changer from a truck that has the vertical mount suspension.
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
squarehead
Nov 21, 2014 08:02 PM
x7x7
Aug 15, 2002 06:49 PM
Wilson
Jul 21, 2002 05:08 PM
