Do I need better valvesprings?
Old Nov 19, 2004 | 10:47 PM
hellostop's Avatar
Do I need better than stock springs, does a blower affect spring tension?
I'm tryiing to get a 94z running with a D1sc, headers, stock block heads cam springs. I pulled valve covers and exhaust spring on #6 is broken near bottom. can I change on car? @ tdc? is it a big job? should I put LT4's on - they're relativey cheap.
thanks
Old Nov 20, 2004 | 03:55 AM
SMOKNZ's Avatar
Re: Do I need better valvesprings?
Yes you an change them in the car. There are kits that will screw into the sparkplug hole and allow you to use compressed air to hold the valves up while changing springs. I also have a spring compressor from MAC tools that is small enough to use in the car.
HectorM52
Jul 30, 2017 11:46 AM
MattK
Sep 5, 2003 10:45 AM
gbelli
Apr 21, 2003 11:49 AM
InjectedSS
Apr 16, 2003 08:19 PM
big dave
Advanced Tech
Feb 6, 2003 06:46 AM
