Adjusting the clutch?
Old Nov 5, 2004 | 02:43 PM
Periculum's Avatar
Anyone know how to adjust the clutch in the v6 3800 camaro? I also have a honda crx that is really easy to adjust, there is a little cable going to the transmission with a ring that will move the cable up and down. I cant find a cable like this on the camaro, is there one? Im not sure if the difference between a cable and hydraulic clutch would remove this adjustment or not.
Old Nov 5, 2004 | 05:22 PM
ianwells100's Avatar
Re: Adjusting the clutch?
i dont believe u can adjust our clutches, they are self adjusting...
i may be wrong, but i believe this is what i've heard to be true, whats wrong with it, anyways?
Old Nov 5, 2004 | 05:48 PM
viper03af's Avatar
no adjustments for them
Old Nov 6, 2004 | 04:35 AM
oil pan 4's Avatar
Sure you can ajust the clutch if it's a mechanical clutch.
But your camaro isn't a piece of crap import with a machanical clutch. Your car has a hydraluic clutch and you can't ajust it. It's better of that way.
Old Nov 9, 2004 | 08:40 AM
Periculum's Avatar
The reason I ask about adjusting is that you can cause the clutch to move farther back or farther forward, ricers tend to do this so they can tap the clutch pedal and it will stop the tranny for quick shifts. I was wantin to do it cause it seems to stop the tranny more effectively, the farther back it is. And I dont know about you guys but my tranny is rather picky about when it shifts (hard to go in first from a standstill and sometimes hard to shift into other gears while moving). Sucks that I cant adjust it.
Old Nov 9, 2004 | 10:08 AM
camaros_4_lfe's Avatar
just practice with it..and going into first dont take force but just feel it out better
sleeperZ96BT
Sep 9, 2015 08:28 AM
raroz28
Sep 8, 2015 06:10 AM
karpetcm
Aug 14, 2015 03:02 PM
Jlo
Jul 29, 2015 03:52 PM
Chevyguy358
Parts Wanted
Jul 20, 2015 07:42 PM
