Low mileage 12 bolt
Old Nov 1, 2004 | 09:43 PM
LTOne4Fun's Avatar
Low mileage 12 bolt
Around 4000 miles, 3.90s gears, all options you can get from Strange, LPW Alumin support cover, 33 spline axles, Heavy Duty Eaton posi, and no gear noise a rooarin! Setup for a non TCS car, reluctor ring on the differential
Has LT1 backing plates on it, but I put it in a LS1 car also using my LT1 brakes, or if you wanted to put it under an LS1 all it should take is pressing off the axle bearings and swapping your backing plates on i, and I can get you new axle bearing of your choice for $80 in either the tapered bearing (best for cars that see side to side loads - the bearing Strange usually uses) or the straight roller bearing (more oriented towards front/back loads - the bearing Moser uses)
Never been under anything faster then a 12.50 car so I really dont need it. After asking a couple people Im looking for $1800. Around $2450 new, and sans the 4 week wait ffrom Strange 3.90s are pimp gear for auto guys torn between 3.73 and 4.10s, and 6 speed guys spraying
Old Nov 1, 2004 | 10:31 PM
xxsaint69x's Avatar
Re: Low mileage 12 bolt
mail
Old Nov 2, 2004 | 06:21 AM
ABA383's Avatar
Sent you a PM
--Alan
HectorM52
Jul 30, 2017 11:46 AM
canbaufo
May 17, 2015 10:35 AM
maybe2fast
Mar 16, 2015 09:45 AM
canbaufo
Feb 24, 2015 10:27 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
