Is it OK to leave pressure on solenoid?
Old Oct 31, 2004 | 01:47 PM
kevmor99's Avatar
If I don't have a purge solenoid, is it ok when you turn off the bottle, but theres still pressure in the line on the solenoid? I heard you need to use a purge to relieve the leftover pressure just in the line.
Old Oct 31, 2004 | 03:44 PM
RacinLT1's Avatar
Re: Is it OK to leave pressure on solenoid?
yes,leaving pressure in the line can and will damage the solenoid seals over time. always get rid of the pressure either by closing the valve and making a quick run to drain the line,or crack open the line to bleed off pressure.
HectorM52
Jul 30, 2017 11:46 AM
timmy39120
May 8, 2015 11:41 AM
Fatdog2
Apr 27, 2015 10:32 PM
BigWil
Mar 29, 2015 12:24 PM
Victory Racing
Sep 12, 2002 05:41 PM
