Need to remove the wipers.
Old Oct 29, 2004 | 03:01 PM
LT1grunt's Avatar
Because they they stop 6-7 inch up on the windscreen when I turn them off. Have unscrewd the nut, but they just wont move...
Old Oct 29, 2004 | 05:05 PM
Kataklysm's Avatar
Re: Need to remove the wipers.
Theres nothing to unscrew. Theres a little tab that you press in then just slide them off.
Old Oct 29, 2004 | 06:15 PM
Mtrhds94Z's Avatar
He means the wiper arms not the wiper blades..
They are on a tapered splined shaft and can be difficult to pull.. some use a puller[ like an old batter terminal puller]
I usually can get em by prying carefully..
Also, if the wipers aren't 'parking' don't just reorient them.. it isn't that it's the circuit board in the wiper motor that's bad..
Old Oct 29, 2004 | 06:16 PM
I doubt taking the arms off an repositioning them is going to fix your problem. Likely a problem with the motor control.
greenzee28
Sep 25, 2015 04:29 PM
Jake Bialke
Sep 24, 2015 11:31 AM
wbspoon
Sep 19, 2015 08:12 AM
NewsBot
Sep 14, 2015 09:20 AM
RX Speed Works
Sep 11, 2015 03:31 PM
