Will aftermarket tune fail emissions?
Old Oct 26, 2004 | 03:08 PM
rlax31's Avatar
I read on the board that this might be a problem. My check is coming up in a couple months, and I'd like to know
Old Oct 26, 2004 | 03:11 PM
madwolf's Avatar
Re: Will aftermarket tune fail emissions?
Do you have your emission devices in place?
What modifications?
Old Oct 26, 2004 | 03:39 PM
Alvin@pcmforless.com's Avatar
Make sure the tuner isn't removing emmissions checks.
That will make it fail the plug in OBD2 test.
Old Oct 26, 2004 | 04:00 PM
rlax31's Avatar
Ion you tuned it i had to have it tuned for the A4-M6 swap, and you tweaked it. Emmssions things should have been taken off
Old Oct 26, 2004 | 04:04 PM
madwolf's Avatar
Sorry... it was a year ago after all. You will pass without any problems as far as programming is concerned.
Old Oct 30, 2004 | 12:17 PM
superkia8's Avatar
Uh Oh! So if you do not have your AIR and EGR hooked up, are you still able to pass the OBD2 plug in emission test with computer tuning? I thought I would be able to have them tuned out so I could pass???? Now Im worried!
Could someone please enlighten me on this.....please!
Thanks,
Rich
Old Nov 3, 2004 | 01:50 PM
Team ZR1's Avatar
If tuned properly and the smog station is only doing EPA I/M tests with a PCM scanner then most mod'd cars can still pass.
I have gotten cars without CATs or SC'd with larger injectors to pass the I/M tests.
Pre 2001 cars are allowed up to 2 of the IM tests to fail.
01 and newer only one test allowed to fail.
Most cars fail because the owner pulls the battry or deletes DTC error codes which forces all I/M tests to revert back to a Non Complete (failed) state and now can take up to 40 valid drive cycles for some tests to get back to a Complete ( passed) state.
Old Nov 4, 2004 | 06:08 PM
superkia8's Avatar
Been a little busy with work but wanted to say thanks for the reply.......THANKS FOR THE REPLY
Old Nov 9, 2004 | 11:26 PM
NovaTodd's Avatar
Question Re: Will aftermarket tune fail emissions?
Not to change the subject, but is there a published procedure to get the computer back to a complete state? I have a 2000 Silverado w/ the 4.8 and have exactly that problem. I cleared a code about 3 months ago. Took it for a smog test and failed last weekend. I just don't know what area of the self test the truck is not comleting. I do know the truck is not completing the cat, egr, and fuel evap tests. Any ideas?
Todd
Old Nov 10, 2004 | 03:48 PM
Team ZR1's Avatar
Todd
Some tests such as CATs and AIR which are tested only once per drive cycle can take as many as 40 cycles to complete.
A valid drive cycle must start below 120 water degrees and must exceed 160 degrees ( if someone did not tune and change open/closed loop values)
EPA did this so someone does not just turn key on/off 40 times and trick the test to complete.
If the engine makeup and/or tune prevent getting to lets say 160 degrees then the tests would take many more drive cycles to complete, esp in cold weather.
To speed up most relearn of PCM you start with open loop, let idle till closed loop engine, use half throttle to get to 55 MPH.
Stay at 55 for 5 minutes then without using brakes or shifting let engine get below 20 MPH
Then use 3/4 throttle and repeat and after 5 minutes at 55 MPH let car coast to stop, idle a few seconds and turn engine off.
This does NOT cause all tests to relearn but most of them.
Old Nov 10, 2004 | 07:23 PM
NovaTodd's Avatar
Thanks for the info. I'll give it a try. I just need to get the thing passed the smog check before the end of the month (at least I have more time than normal!)
IgorT.455/406
Mar 12, 2015 03:39 AM
FredM
Exhaust System
Feb 18, 2015 05:37 AM
Jazsun
Dec 29, 2014 12:14 PM
