Project Front Mount!
Old Oct 12, 2004 | 09:54 PM
c0rey's Avatar
Hey I was wondering what you all think of this Idea! Im gonna remove the AC condensor/compressor and the whole system. I want to put the intercooler where the ac condesor used to sit so that it can stay hidden and also catch alot of air. Let me know all your suggestions. Also post up pics of lt1s with front mounts !!
Old Oct 12, 2004 | 10:30 PM
95_LT1_6SPD's Avatar
Re: Project Front Mount!
That would be pimp.
Old Oct 13, 2004 | 03:25 AM
TimbrSS's Avatar
I'm not sure, but putting the intercooler right infront of the radiator might not be the best idea as far as keeping the motor temp down, since it will not only be a restriction, but will heat the air up going to the radiator as well. Mounting the IC up further allows it to get it's air from the front of the car, while the air deflector will direct cool air from underneath to the radiator.
Old Oct 13, 2004 | 09:16 AM
mongse_1's Avatar
The easiest way to do it is to remove the front crash support and mount the intercooler there. If you've got an ATI 3-core, it'll mount up almost perfectly w/ the holes on the frame butts. There's several sites that show how to do this. I wish I would've taken more pics when I had it on my car though. I don't think you'll have much room where the AC condenser was.
Old Oct 13, 2004 | 10:04 AM
Pro Stock John's Avatar
There is a thread on www.ls1tech.com in the FI section with pictures of like 20 different FMIC setups.
I took out my front bumper support and ac.
Old Oct 17, 2004 | 03:11 PM
frcefed98's Avatar
Hi Corey, its pretty simple to do if you mount it to the bumper support and gives you awesome ground clearance on both camaro's and firebirds alike(stock ground clearance) Excellent airflow to the FMIC on both models too.
just an idea of how to do it. Probably have to click on the links tho
****pics down sorry****
HectorM52
Jul 30, 2017 11:46 AM
Jun 6, 2015 08:27 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
