T-trim versus T-76
Old Oct 10, 2004 | 03:20 PM
engineermike's Avatar
T-trim versus T-76
I was thinking about twin turbo's, but packaging seems difficult, so I started entertaining a single. It occured to me that the most common single turbo V-8 uses a T-76 and they seem to be in the 700+ rwhp range. Checked out the compressor maps of the T versus the 76 here:
http://www.vortechsuperchargers.com/...-trim_map.html
http://www.forcedinductions.com/help.htm
and found something interesting. There isn't much difference between the two. At a typical boosted V-8 2/1 Pr (~15 psi) and 70 lb/min (550 gm/sec), the T is 71% eff versus the T-76 at 72%. Move out to 80 lb/min (630 gm/sec) at 15 psi, and the T is 70% versus the T-76 at under 65%. So, at higher flow rates (hp), the T is actually more efficient than the T-76.
Close examination of the T-trim compressor map reveals that it can build ~20 psi boost if spun to 50,000 rpm (max efficient speed) while flowing 550 gm/sec. Does anyone go this route and actually get 20 psi from a T-trim and make 700 rwhp?
Mike
Old Oct 10, 2004 | 10:04 PM
Sneakin Deacon's Avatar
Re: T-trim versus T-76
only experience with a T trim is on a mildly built 302, he put down 630ish on 14psi.
id honestly go with a turbo setup, it takes almost 100hp to spin the T trim for ~10# (varies car to car)
Old Oct 11, 2004 | 12:48 PM
Birdie2000's Avatar
I'm not knocking the T-trim, heck I have one lol, but the turbo will probably make you happier since it can build boost off of the line and will get to peak boost much quicker. Remember, area under the curve means a lot, but I'm sure you know that.
Old Oct 11, 2004 | 01:20 PM
True, but with the 4000 stall converter, I'm making 10 - 13 psi at all times.
Old Oct 11, 2004 | 01:56 PM
Birdie2000's Avatar
Out of curiosity, what are peak and shift rpms with that cam?
Old Oct 11, 2004 | 06:20 PM
Peak hp is at 6500 rpm according to Thunder Racing's Dynojet. I shift at about that also.
Mike
Old Oct 12, 2004 | 04:15 PM
Pro Stock John's Avatar
I made 746rwhp with a YS Trim.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
RUENUF
Mar 13, 2016 03:37 PM
JohnGuc
Jul 11, 2003 10:46 AM
AFast83z28
Apr 6, 2003 12:15 AM
