Squeaking When Turning Left Only???
Old Oct 7, 2004 | 11:51 PM
BoobSter-lt1-z's Avatar
Question Squeaking When Turning Left Only???
Alright here it goes...
When i make a left turn, and only a left turn, between 15 -25mphs there is
a squeak from when the back begins to make the turn until the back is straight once the turn is complete. Its not the breaks as i thought it was
since i dont hit the breaks when turning left at a light if there are no cars coming. The squeak sounds like when your brakes just begin to go out and its a high pitched squeak and not a grind. I cant figure out if its coming from the front or the back. The front end is pretty sloppy because it feels really loose and in small 15mphs speed bumps going at 10mph i hear clunking in
the front....anyone have any suggestions on what might be causing this squeak>??????
Old Oct 11, 2004 | 02:27 AM
wbna0149's Avatar
Re: Squeaking When Turning Left Only???
Have you looked at your front spindle bearings, I ould gues the right front might be worn. Check both any ways
Old Oct 12, 2004 | 12:34 AM
SkillZ25's Avatar
Where are the spindle bearing located?
Old Oct 12, 2004 | 09:49 PM
Thats The Same Question I Have...i Dont Know What It Would Look Like
Old Oct 12, 2004 | 09:57 PM
LPEdave's Avatar
This might help - http://www.go-fast.org/z28/diagnostics.html#turn-squeak
Dave
Old Oct 12, 2004 | 10:14 PM
Excellent Website!!!!!!
Thanks A Lot!!
CaRParts102
Dec 6, 2014 08:45 AM
WIKIDTA
Aug 12, 2002 12:57 AM
formula79
26
Aug 5, 2002 12:21 PM
91 Redd Sledd
Aug 4, 2002 04:28 PM
91Bird305
Aug 2, 2002 02:53 PM
