Vibration and stuttering...
Old Oct 1, 2002 | 08:50 PM
2nd2sex's Avatar
Angry Vibration and stuttering...
1997 v6 w/44k on it. This is the first problem that Ive had with the car. Two days ago I had a problem with my car, It started to Vibrate and stutter and then I got the Service Engine light come on. Under moderate to light acceleration the car drives fine most of the time until about 60mph then I get the hesitation and sometimes the Service light will begin to flash. Once Im at a stable speed like 40mph the car drives fine. Any light acceleration and the car will seem to be normal but if I accelerate too fast it will act up?? The car turns on fine and still drives. Does anybody have a clue as to what is going on??
Old Oct 1, 2002 | 09:27 PM
Purplehaze's Avatar
Do you have a aftermarket cold air intake?
If you do,the problem could be a dirty maf sensor
I had similar symptoms and that was found to be the problem.
One of my K&N filters had actually fallen off inside the little compartment(SLP cold air) and the maf sensor had gotten pretty
dirty before it was discovered.
Old Oct 1, 2002 | 09:36 PM
2nd2sex's Avatar
you are probably right it does have a K&N intake and before all this happened for about 2 weeks there was a rattling noise near or in the intake...Ill have to check it out. Thanks
autoxr166
Sep 25, 2015 04:21 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
Apr 16, 2015 09:57 AM
