New Clutch
Old Oct 1, 2002 | 07:34 PM
Rob94's Avatar
New Clutch
The clutch in my car has died at 59,000 miles and i am going to have it replaced soon with a aftermarket one, possibly Centerforce. Recently i have heard bad things about this clutch including a rumor that it will begin to slip in something like 5,000 miles. Is this true? is so what clucth should i get?
Old Oct 1, 2002 | 10:50 PM
stars1010's Avatar
Thumbs up
Mines still badass after about 7000 miles on it.
Old Oct 9, 2002 | 03:56 PM
Ramzee 28's Avatar
Wink
No offense Rob and Stefan, but you both have 3.4L engines. I know 1000 rpm's is still 1000 rpm's no matter what, but we are talking clamping force on the flywheel of a V6 not a V8. My personal opinion would be that money would be well spent elsewhere on the car than a performance clutch. When I clutch shopped for mine, I remember reading someone say that the stock clutch is not a bad clutch up to a certain amount of HP and torque. Provided the fact that nothing is leaking of course, i.e. - rear main seal, input shaft seal, or slave/master cylinder. Unfortunately for me all 3 went bad this summer, taking my stock clutch the first time, a new stage 3 carbon the second, and now the damn rear main is leaking again. But I am going to catch it before my clutch gets damage this time. By the way, who ever stated that you should change your rear main seal when doing the clutch? Dont! I put 2 Felpro Teflon rear main seals in this summer and they are junk. I think they are the only felpro gasket I will not stand by. I went to get one at the GM dealer and noticed the GM gasket had a tension spring to hold the seal against the hub. Hmmmn? Felpro dont have that?
Just my $.02 though.
-Israel
Old Oct 9, 2002 | 06:32 PM
stars1010's Avatar
Oh I understand the weakness of my motor, but you also have to understand that I blew my last two stcok clutches within about a year. I used to drive my car way too hard. So I thought that since I had the money I might as well put something in there that is going to last. So far so good. I like my dual friction.
Old Oct 9, 2002 | 06:53 PM
Tiago's Avatar
CF DF
haven't seen any slip in ~10k miles
I drive that bitch hard too...and I got power.
Old Oct 9, 2002 | 07:43 PM
MustangEater82's Avatar
I may agree with above, my motor is stock internally, and I jsut installed my 4th, yes no typo 4th clutch. Last one lasted 15k, and was installed by the dealer.
I really considered a CF DF, and woudl have gotten one if the money was in my account.
Old Oct 10, 2002 | 12:22 AM
Rob94's Avatar
sadly enough i can't afford the dual friction. The one i plan on purchasing is the centerforce II i think? It says it holds 30% better than stock, has anyone had any experiences with tihs clutch??
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
