Looking for BIG power from a 396. Here is what I have ... what do I do now?
I am looking into buying a 96 Z28 with a 396. I want to put a turbo on it, and make BIG power!!! It is now making 400rwhp with the 396 and no port work on stock lt1 heads and just an lt4 HOT cam, so it seems to be making great power for such a mild but super strong setup. It is at about 12:1 now so I know I need to get different heads to drop the compression. What can I get away with buying in terms of heads and what do I need to know (other than tranny or rear end wise) to make big power? IE: 600rwhp-1000rwhp??
396 stroker lt1
-callies roating assemblie
-30# svo injectors
-canton 7qt. roadrace pan
-bbk 58mm tb w/ portmatched intake
-k&n fipk
-splayed mains (4 bolt main)
-all arp bolts
1le a/c delete
-ati superdamper
-hooker ceramic coated long tubes
-hooker y pipe
-magna flow stainless catback
-meizer heavy duty water pump
-slp fan switch
-custom dyno tuning w/ wide band
-spec stage 3 clutch
-ngk plugs
-msd 8.8 wires
-poly motor mounts
-heavy duty timing chain
-crane gold race rockers 1.6
-lt4 hotcam.....so small
-srp pistons
396 stroker lt1
-30# svo injectors
-k&n fipk
-all arp bolts
1le a/c delete
-ati superdamper
-hooker y pipe
-slp fan switch
-ngk plugs
-msd 8.8 wires
-poly motor mounts
-srp pistons
Re: Looking for BIG power from a 396. Here is what I have ... what do I do now?
Wow....to be honest i wouldnt even be thinking blower with this motor unless you were willing to really drop that compression alot. I mean heads would help but from the way it sounds like this motor was built I would put the bottle on this car in a heart beat, I would probably put in a healthier cam too.
Using the compression calc on this site. It looks like putting on a set of AFR's with 76cc chambers would bring the compression down to ~9.4:1 wich is about the best you could hope for without changing the pistons.
-Tony
-Tony
Thanks for the help! Realistically, if I were to get a remote mounted turbo and say a custom turbo cam with those heads, what type of numbers could I get from pump gas on a good tune?
Realistically what kind of budget are you working with? To make big power and still stay streetable you are going to have to spend a pretty penny.
I am putting into factor that I will already have the motor, which apparently cost about 8k to build. I am not taking into considerationg the tranny or rear end, as I am really just looking for numbers right now on the dyno. I don't really know what I am going to be spending - but I assume I would need 2k for the heads and 4k for a turbo setup and some cash to get it tuned. Anything else I am missing?
ok that makes sense. I'm sure I'd need a cage but I hate those things (haha). What kind of fuel system am I gonna need and how much would it cost? Also, anything I should look out for? Do I have any business even attempting this?
In all honesty it takes alot of time, dedication and money to get your car to run right. Don't expect to put your car together and instantly run 600 rwhp. There is alot of useful info out there if you do a search. Boost is addictive and I can tell you for a fact that you will end up spending more money that you initially anticipate. Trust me I know because I have been there.
i also agree (been there) fuel system ,big injectors, good computer for tuning(wide band),strong drive train,good chassis comp.,intercooler ............
Your best bet is to spray this set-up and go boodt down the road with a different set of pistons.
Everything else should work fine for the boosted application, but the compression should ideally be about 9:1.
Wow, where to start? With a budget, IMHO. It's hard to be at all specific without knowing what you are planning to spend. Most of the time a project like this ends up 2-2.5X what you originally thought it would!
Rich
Rich
carguyshu
Jan 22, 2017 11:19 AM
Sergio
Jan 27, 2016 04:27 PM
