Paxton kit on an LT1?
Old Sep 22, 2004 | 09:26 PM
'68LT1camaro's Avatar
Does anyone have pictures of, or know of any links to pictures of a Paxton supercharger kit on an LT1?
THANKS!
____________________________________Raymond
Old Sep 23, 2004 | 11:29 AM
Roadie's Avatar
Re: Paxton kit on an LT1?
There's not much to see, especially from the bottom-side. Here's a pic
Mine isn't stock though. I have long-tubes, so the first big change was creating a new #1 slip-fit primary to work around the paxton tubing. It's jet-hot coated to match the headers.
Next, I replaced the Paxton elbow (~135 degree bend) with a Vortech elbow (90 degrees), a 45 degree rubber elbow to put the MAF after the blower, and a hump hose to reduce the 3.5" MAF to the 3" paxton tubing.
Later on, I tig'd an aluminum tube on to the paxton tube (before the MAF) to attach a surge valve to release extra pressure when the throttle blades are closed (vacuum present in the manifold). This is not shown in this picture.
No pics of the bottoms side. It's just a head unit bolted to a bracket, bolted to the block.I added a hunk of solid 3.5" tubing to replace the MAF in the supercharger inlet tubing.
Old Sep 24, 2004 | 06:41 PM
Thumbs up Re: Paxton kit on an LT1?
Thanks Roadie . Thats better than no pic at all.
Old Sep 25, 2004 | 12:00 AM
Highlander's Avatar
I havea video of a dyno run of my car with the paxton
Old Sep 25, 2004 | 11:49 AM
Do you have any pics of the kit on the motor, or the kit by itself?
D1SC383LT4
Jan 1, 2016 01:56 PM
Jan 23, 2015 01:13 PM
CARiD
Jan 14, 2015 04:00 AM
CARiD
Dec 26, 2014 04:20 AM
Dec 4, 2014 11:56 AM
