Line Lock Question???
Old Sep 22, 2004 | 09:01 PM
Camaro4LifeSS's Avatar
This is probably a dumb question but I have to ask because these are my brakes.I looked inside the Hurst line lock to see what flare I need to make for it and I all I see is a screen.Hard to tell which flare I need.Can I use any flare or do I have to go double?I'd rather go double flare if I could.
Thanks for your time.
James
Old Sep 22, 2004 | 09:15 PM
97FormulaWS-6's Avatar
Re: Line Lock Question???
I'm running a TCI, and I had to buy adapter fittings, the Line-Lock was threaded with NPT threads, not a flare-style setup. I got the fittings at the local parts store, cost like $6 total.
Old Sep 22, 2004 | 09:23 PM
So do I need to flare my line?I have some fittings that screw into the line lock that I bought at Napa.As long as they are the same thread then their all good right?Now I just need to know about my flare.
Thanks for the info man.
JE
Old Sep 22, 2004 | 10:47 PM
I hate to rush for help but I plan on getting back at this in the morning so if anybody knows please respond.Again I just need to know what flare I need for my brake line to hook up to the Hurst Line Lock?
Thanks in advance,
JE
Old Sep 22, 2004 | 11:40 PM
BTracecars's Avatar
You should double flare your lines. also be carefull about what fittings your using, because your lines should be metric. hurst makes an adapter fitting kit for 93-00 f-bodies, part # 567-1515 it is for use with their roll control #174-5000.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
Feffman
Oct 9, 2015 05:42 AM
capebuf
Jan 13, 2015 07:22 PM
GA93FORMULA
Jul 24, 2002 11:38 PM
