Gear Size??
Old Sep 21, 2004 | 06:34 PM
97LT1Z's Avatar
Gear Size??
How would I find out what the stock gear is in my 97 Camaro Z28 A4?
Old Sep 21, 2004 | 07:44 PM
Fuels94TA's Avatar
Re: Gear Size??
most likely you have 3.23 for stock gear.
Old Sep 21, 2004 | 08:04 PM
97LT1Z's Avatar
Re: Gear Size??
i have heard either a 3.23 or a 2.73
Old Sep 21, 2004 | 08:14 PM
BiGGinZ's Avatar
Re: Gear Size??
P-r-n-od-d-2-1 3.23's
P-r-n-od-d-2 2.73's
Old Sep 21, 2004 | 08:47 PM
Capn Pete's Avatar
Re: Gear Size??
GU2, 2.73's
GU5, 3.23's
Check the sticker on the driver's side door.
Old Sep 22, 2004 | 10:01 AM
BiGGinZ's Avatar
Re: Gear Size??
See now you have 2 different ways to find it. Tell us what you find.
Old Sep 22, 2004 | 10:12 AM
2001NBMZ28's Avatar
Re: Gear Size??
And if you suspect they're not stock check out the gear calculator at www.f-body.org/gears/
Old Sep 22, 2004 | 04:19 PM
Kataklysm's Avatar
Re: Gear Size??
P-r-n-od-d-2 2.73's
In case you don't understand this, if you can select first gear on the shifter then you have 3.23s. If not, you have 2.73
Old Sep 22, 2004 | 04:21 PM
BiGGinZ's Avatar
Re: Gear Size??
Yep just in case
HectorM52
Jul 30, 2017 11:46 AM
ChrisFrez
Mar 22, 2015 09:12 AM
ChrisFrez
Feb 15, 2015 08:12 AM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
