Just had oil change
Old Sep 19, 2004 | 10:49 AM
1dreamz's Avatar
Just had oil change
Hey guys, I just had an oil change and went for synthetic blend oil, on the sticker they say my next oil change isn't due for 150000 miles. Surely this can;'t be right? Is the synthetic blend oil worth the extra money?
Old Sep 19, 2004 | 10:56 AM
Mindgame's Avatar
Re: Just had oil change
15,000 mile?
That's excessive. 4-5,000 might be ok if filtration is good but I wouldn't want to push a synth-blend too far down the "extended change interval" ladder. Of course you could always have an oil analysis performed to see how the oil is performing at ~4000 miles. Just a thought.
-Mindgame
Old Sep 19, 2004 | 11:50 AM
Strahley's Avatar
I would say 150,000 was a misprint. Yes, synthetic is worth the extra money. If you don't like spending the extra money on synthetic, do the oil changes yourself. You'll spend more money doing an oil change with basic oil than buying the synthetic oil itself. Changing oil is not hard, you don't even need to lift the front end up sometimes
Old Sep 20, 2004 | 06:03 PM
BirchMan98z's Avatar
I use mobil 1 oil, & a mobil 1 filter, and I do oil changes every 3000-4000 miles whether it needs it or not. 15000 is crazy. The synthetic oil can stand more abuse, but a few WOT passes will foul up the oil more than just everyday average driving. I'd say don't go longer than 5000-6000 miles.
Old Sep 20, 2004 | 10:41 PM
psychocabbage's Avatar
wtf?
on a camaro? not lift it up? you running a 4x4 drivetrain? have 80 series tires? how do you change the oil without lifting up the car?
Old Sep 20, 2004 | 10:42 PM
Originally Posted by robvas
The Corvette advertises a 15,000 mile oil change interval, I think.
I wouldn't let it go much past 5000.
I am at 11Kish since my last change.. I do it myself.. I also only do it when the light comes on telling me to do it..
I only use full syn.. Lately Mobil 1
Old Sep 21, 2004 | 10:10 AM
RS Dragster's Avatar
There's been a lot of debate on the subject, so it'll be IMPOSSIBLE to get actual facts. For example, IN MY OPINION, you can go at least 5K on it. Think about it. Just regular oil is suppposed to be good for 5K now. The only reason the 3K mark is still advertised is because the oil company makes more money. Think about it. You think they'd want everyone to go 15K miles if they could get 3X as much $$$? Hell no.
So yeah, the only way to really know is run her up to 5K, get it tested. Then if you can, run it to 7K, get it tested. Keep seeing how it does. I'm sure it'll be fine all the way up to 10K at least.
Good luck
Old Sep 21, 2004 | 11:38 AM
Robert95z's Avatar
I beat the hell out of my lt1, i use full synthetic and always change at 3000 miles. But i work at a oil change place so i get oil at a decent price.
Old Sep 21, 2004 | 02:16 PM
WOT's Avatar
WOT
Thumbs up Re: Just had oil change
Good luck
It's not impossible. Just use oil analysis (as you said yourself) www.blackstone-labs.com It's the only way to get scientific results.
Old Sep 21, 2004 | 02:41 PM
roadkillZ28's Avatar
I believed the oil change light is only counting down miles every reset and its not a sensor!
so GM set that light for any normal oil not for synthetic..
Old Sep 21, 2004 | 03:01 PM
Jay3274bbl's Avatar
You said syntheic blend, why not go for the full synthetic ?
Good web forums for oil.
http://theoildrop.server101.com/ubb/ultimatebb.php
Old Sep 21, 2004 | 10:46 PM
Actually, our engines from what I have seen had synthetic in them from the factory but its not advertised that way.. When I changed all the fluids in my car at 13K miles they were all syn..
In any case, the sensor turns on at differnt times.. At least for me it has..
Waiting for the next activity.
Old Sep 21, 2004 | 11:49 PM
Strahley's Avatar
wtf?
Long arms and the torque to go with them can get you a long way
Old Sep 22, 2004 | 11:37 AM
SpeedDemon02SS's Avatar
I use Mobil 1 all the time from the first day i had it. I also change every 2500 - 3000 miles...if you race your car, or even have fun with it, its best to change early, it will give your engine a longer life...unless your looking to blow it up for an excuse to put in SLP's new 402 Shortblock! :-)
Old Sep 22, 2004 | 04:42 PM
My car isnt lowered and I have a heck of a time just getting my shop jack under there.. I just cant imagine doing it on flat ground.. hahha
