Charge is fine when I start it; drops into yellow when e-brake is released
Old Sep 17, 2004 | 04:12 PM
mark896's Avatar
I've had this problem for about a year but want to fix it now.
When I start the car, all is well. For some reason, once the emergency brake is released, the charge meter will drop into the yellow and when I'm driving it will dip in and out of the red. Battery is a year old (I changed it once the problem started) and now I just put an alternator on it.
What I've been doing as a temporary fix is releasing the e-brake just enough so that it physically doesn't grab anymore, but the sensor still thinks it's engaged and the "BRAKE" light stays on. Annoying as hell.
To be honest I haven't checked the fuses but would that be a fuse-related problem?
Old Sep 17, 2004 | 09:10 PM
1stls1's Avatar
Re: Charge is fine when I start it; drops into yellow when e-brake is released
Just for kicks, check ALL of the grounds. You may have a loose ground wire around the e-brake. Was there any work done to any of this when you notice this problem? Also, it may not be a good idea to keep the e-brake up, you could be wearing down the brakes!
Old Sep 18, 2004 | 04:41 AM
AL SS590 M6's Avatar
Moderator
If you start the car with the e-brake on the auto daytime running lights are kept off. When you release the e-brake the lights come on causing the extra drain on the charging system. If the battery is new then the alternator is probably weak. I'd get the batt and alt checked.
Old Sep 18, 2004 | 11:09 AM
mark896's Avatar
They're both brand new though. I don't know. It doesn't make sense. DRL's don't drag THAT much.
Old Sep 18, 2004 | 09:36 PM
2002Z28SSConv's Avatar
I also was thinking it must be DRL related. There could be a short in the DRL circuits somewhere that pulls more power than normal but still allows the lights to work. Possibly a relay or switch.
Old Sep 20, 2004 | 12:47 AM
Moderator
Originally Posted by mark896
They're both brand new though. .
Don't get hung up on the notion that just because they are new parts that they have to be good. They could be defective. Not to hard to get an alternator or battery checked.
Old Sep 20, 2004 | 06:04 PM
BirchMan98z's Avatar
Do you have an ASP pulley system or anything like that? Sometimes they can drain power if you have a lot of accessories running... stereo, lights, etc.
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
97SSdude
Dec 31, 2014 07:43 PM
cristian1311
Nov 23, 2014 02:22 PM
