Spohn Torque Arm problem
Old Sep 10, 2004 | 11:30 PM
INFERNO's Avatar
Question Spohn Torque Arm problem
I have a 1993 Z28 and I just got a spohn body mount adsjustable torque arm from a board member. Everything on the arm is perfect. I got it properly installed and adjusted at work today. The problem is that whenever shifting hard, downshifting, or hitting a good bump in the road it sounds like someone is hitting the underside of the car with a 100Lb sledge hammer. Everything is tight and there are no clearence issues becuase I checked everything with the suspension fully loaded and unloaded. It sound like it is coming from the polyurethane bushing that mounts the Torque arm to the crossmember behind the trans. Anyone have this problem. I did a search but did not come up with anything helpful. Thanks.
Old Sep 11, 2004 | 02:54 AM
smoknta's Avatar
Re: Spohn Torque Arm problem
Did you leave the tranny mount or torque arme mount unbolted? That sounds like what happen to me whey I broke the tranny mount.
Old Sep 12, 2004 | 12:46 AM
INFERNO's Avatar
Nope, Everything is tight. I checked everything a couple of times. Still so far clueless.
Old Sep 12, 2004 | 02:12 AM
Z-RATED94's Avatar
There just a little noisy. One of those things you have to live with when you wanna go fast.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
