Help! They stripped the lug on my wheel...
Old Sep 10, 2004 | 09:45 PM
ford's Avatar
The bolt that your lugnut screws on to and whatnot, apparently when they mounted the wheel last they just used the gun and didnt thread it by hand first. So when i took it off the thread is completely stripped now.
How do i fix this.
And thanks!
Old Sep 10, 2004 | 09:50 PM
95GRNZ's Avatar
Re: Help! They stripped the lug on my wheel...
Originally Posted by ford
How do i fix this.
By knocking the stripped one out and replacing it with a new one. Quite easy to do. Usually easiest to do if you have air gun, though.
Or go back to the place who did that and have them do it.
TS
Old Sep 10, 2004 | 09:55 PM
ford's Avatar
Cool just a hammer and a little muscle then, when i looked at it that appeared to be all there was to it. But if ive ever learned one thing, its that its never that simple.
Ill just do it myself if its a easy fix, easier than the hassle IMO.
david97gsxr's Avatar
easy fix.
go to autozone and ask for a wheel stud for your car.
take your wheel off, knock the old one out with a hammer.
slide the new stud in, put a couple washers on it, and put a nut on it and use an air gun,(or you can do it by hand if you don't have an airgun), to pull the stud through. (because you can't hammer it through, you have to pull it through with a nut)
total cost: 2 dollars and some change....unless you need a lugnut too, those are like 4 dollars. i think
Old Sep 10, 2004 | 09:59 PM
ford's Avatar
I have 2 extra lugnuts so thats cool. It makes me happy that its really this easy
Old Sep 11, 2004 | 10:47 AM
IRONFIST's Avatar
I had to do this on my car, but I had to take the caliper/disc off first so I could get to the lugs...
I guess fourth gens are easier
Old Sep 14, 2004 | 12:43 AM
IRONFIST's Avatar
Originally Posted by 1 Nasty Bird
Just dont buy the autozone replacement lugnuts!! I got a set of them and when i had to use my spare tire one of the lugnuts wasnt dep enough so it mushroomed up the last couple threads and wouldnt let the lugnut come off. Just one for some reason but it wouldnt back off with an air gun. They had to wail on it for almost a minute with the air gun and break the stud. So i have 4 lugs on my front tire for now.
similar thing happend to me, except on a honda civic I was fixing. I changed the lug, put it on... and when I went to torque the lug nut, it broke....
Make sure you buy a quality lug.. lol
Old Sep 14, 2004 | 10:39 AM
ford's Avatar
lmao think O'reilys will have a good lug?
Old Sep 14, 2004 | 07:52 PM
i thought you said you had extra lugnuts? eitherway, i got mine at NAPA, and it' looks just like the stocker. worked fine too.
Old Sep 15, 2004 | 04:35 PM
ford's Avatar
I have extra lugnuts, not extra lugs.
Old Sep 16, 2004 | 07:20 PM
blwnlt4's Avatar
autozone and o' riellys both carry Dorman lugs and lugnuts
Old Sep 16, 2004 | 08:21 PM
Zack's Avatar
lugs have always=lugnuts to me
dont know what else 'lugs' you refer to
go to discount tire for some lugs. gorilla lugs. we use them to chase f'd up studs adn they seem to hold up
Old Sep 16, 2004 | 09:11 PM
4 entries found for lugs.
lug1 Audio pronunciation of "lugs" ( P ) Pronunciation Key (lg)
n.
1. A handle or projection used as a hold or support.
2. A lug nut.
3. Nautical. A lugsail.
4. A projecting part of a larger piece that helps to provide traction, as on a tire or the sole of a boot.
5. A copper or brass fitting to which electrical wires can be soldered or otherwise connected.
6. Slang. A clumsy fool; a blockhead.
what you need is a stud
Old Sep 16, 2004 | 11:25 PM
blwnlt4's Avatar
i cannot believe 2 people just posted about the definition of the word lug... i think he knows what the **** were talking about
Old Sep 17, 2004 | 02:29 AM
i'm just doing the guy a favor. so he doesn't go around talking and sounding uneducated. calm down
Quickss96
Jan 29, 2016 05:56 PM
pepon214tx
Sep 20, 2015 04:48 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Navecm
Jun 1, 2015 05:57 PM
