Dead Rear End?
Old Sep 9, 2004 | 08:52 PM
JB_96RS's Avatar
Dead Rear End?
I've read the posts about the humming/vibration coming for the rear ends of our beloved camaro. Mine just started making this noise this summer.. I think this might be a little more severe. The humming is sooo bad that it makes your ears numb after about 30 mins of it! I changed the axle bearings yesterday, but that didnt't fix it. The noise seems to come mostly from the left side and I feel a lot of vibration in the center column, but I can still feel some up by the pedals. I've also heard some "chattering" when I let off of the gas. Is this the rear end $h***ing the bed?
Another thought that I had was: the tires are old, the car sat (used in the summer only) I inspected the tires and they are hard as a rock!! The tread has no flex in it and it doesnt leave rubber when I spin the tires. So my question is... Could the tires be the cause of the vibration and humming because the are tooo stiff? If its the rear end where can I find a 3rd member that I can swap myself.
Thanks for reading,
JB
Old Sep 10, 2004 | 10:47 AM
JB_96RS's Avatar
Re: Dead Rear End?
ttt
Old Sep 12, 2004 | 10:11 AM
JB_96RS's Avatar
Re: Dead Rear End?
Anyone?
Old Sep 12, 2004 | 10:52 AM
KenP's Avatar
Re: Dead Rear End?
JB, back when my car was only 2 years old it had the same problem you are having now. It was so loud you would have thought I had a super charger installed. Turns out that the ring and pinion were trashed. GM fixed that and it was fine until I upgraded to a 12 bolt.
Pull the cover off and inspect the gears and check the gear oil for metal particals. Is your pinion seal leaking also? Mine was.
HTH,
Kenny
Old Sep 12, 2004 | 02:14 PM
JB_96RS's Avatar
Re: Dead Rear End?
The seal did leak. How much did GM charge to fix this?
Old Sep 12, 2004 | 04:14 PM
KenP's Avatar
Re: Dead Rear End?
Fortunately it was covered under warranty.
I had the ring/pinion gear break on my S-10 4x4 a couple of months ago and a shop quoted me $750-$1000 to rebuild it . I just bought a very used rear end from a junk yard for $250 and installed it myself.
Old Sep 12, 2004 | 08:23 PM
JB_96RS's Avatar
Re: Dead Rear End?
Did you buy the whole rear end or just the ring and pinion with the bearings on it? I had that thought but didn't know if that was an option.
Thanks,
JB
Old Sep 13, 2004 | 05:00 AM
KenP's Avatar
Re: Dead Rear End?
I bought a complete rear end.
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
