Junkyard single turbo
Old Sep 8, 2004 | 07:07 PM
lt4 fd's Avatar
Still considering the twin grand national turbos but that could be a pain to plumb and for the power level I am looking for at the moment possibly not needed. Just wondering if there are any singles off larger deisels or buses that may work well with a mostly stock LT1?
Old Sep 8, 2004 | 08:30 PM
97WS6SCharged's Avatar
Re: Junkyard single turbo
If you're looking for a cheapie turbo for a build, try Ebay. They have rebuilt and brand new turbos on there all the time at good prices.
Old Sep 8, 2004 | 11:23 PM
lt4 fd's Avatar
Yeah but I dont know which one to get, Largest ive seen is a holset hx40 which I have not seen a map for. The only brand I know of is holset and of course all the popular aftermarket turbos but are there any turbos that came on any vehicles that may work, most likely off a bus or something...
Old Sep 9, 2004 | 08:52 PM
lt4 fd's Avatar
...help
Old Sep 9, 2004 | 09:03 PM
OUTCAST's Avatar
Originally Posted by lt4 fd
...help
Sent you a PM
Old Sep 13, 2004 | 10:20 AM
Dave Feerst's Avatar
I'm not a turbo expert but I think you would need a different impeller at least if you used a truck/ bus turbo. The impellers are weighted to produce boost at the right RPM and the RPM/CFMs of a car and bus are pretty different.
Old Sep 14, 2004 | 08:21 AM
slickrock55's Avatar
This is correct. Diesel engines have tons more exhaust energy per intake charge than a gas engine. Its common to see a huge 1.4 or so AR on a diesel making something like 200 hp. Slap that on a gas engine and it would begin to spool at around 5 grand and, in general, suck.
Old Sep 14, 2004 | 07:07 PM
texlurch's Avatar
I would agree to that, so far as the large, over the road trucks. I have a pair of GM 6.5 diesel turbos on mine, and they spool just fine, on 1/2 of a 350.
You also have to consider that the diesels only turn 2500-3000 tops, and the turbos are designed to make boost right off idle.
The old "won't spool till 5000 rpm" ain't always true!
RX Speed Works
Oct 1, 2015 10:19 PM
95blkss
Sep 22, 2015 03:18 PM
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 02:02 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
