STS semi related question
Old Sep 5, 2004 | 08:23 PM
lt4 fd's Avatar
I saw on the site, and maybe they can answer, that at 13psi with alky on a stock motor including stock manifolds I assume, that it made nearly 600 rwhp and I forget how much rwtq. I am about to build a turbo setup for a non F-bod car with a stock lt1 with 22cc dished pistons being the only major mod, but the turbos will be in a more traditional location. My question is was that on a stock tune? I would be having mine dyno tuned and probably running 2 intercoolers with whatever that compression will allow (maybe 12 psi ide guess) and have just been pondering if I would see close numbers. I just thought those numbers sounded quite high so maybe there was work done to the lt1 in that particular test... just curious.
Old Sep 5, 2004 | 10:22 PM
trtturbo's Avatar
Re: STS semi related question
If I am correct, that was a completely stock LT1 running 12psi. It did not last; the connecting rods bent. If you have stock rods, I would replace them too. I cant remember about the tune, but rest asured, you need one no matter what. I think the torque was close to 700.
Old Sep 10, 2004 | 09:14 AM
BBB's Avatar
BBB
No, the 'stock' engine (modified LS1 rods in a LT1 and 8.7 forged pistons) made 520 hp and 600 trq. It lasted awhile, but the rods decided to bend. The 600/600+ isn't in catastrophic melt down (as far as my last conversation with Rick at STS.)
BBB
Old Sep 10, 2004 | 09:46 AM
Geoff Chadwick's Avatar
I thought the 600/600+ numbers were done on a 383... That's what I was told.
Old Sep 14, 2004 | 09:42 AM
BBB's Avatar
BBB
I think you are right.
BBB
Magenta_Hearts
Mar 29, 2017 08:54 PM
dbrockma
Feb 16, 2015 02:56 PM
4586
Dec 31, 2014 02:21 PM
Z284ever
53
Aug 7, 2002 11:06 PM
