Several things for sale
Old Aug 31, 2004 | 05:11 PM
chevyguy3's Avatar
All parts are used unless otherwise noted. all are in good condition. prices are firm so dont bother asking what the lowest i will take is
24lb SVO injectors. 1000-1500miles. $150 shipped
B&M Ripper shifter for T56 in F-body. older style with 2 peice handle and adjustable stops. $100 shipped *SOLD*
15lb NX bottle. missing the handle/nut, works fine with a wrench (or you can get a new bottle nut pretty cheap). $110 shipped
MSD window switch with 3000rpm pill (no high limit pill included). $55 shipped
Mallory harness #29068 for hooking up Hyfire6CD ignition box to 93-95 LT1 car. $20 shipped
Walbro GSS307 in-tank 255lph pump. $35 shipped *SOLD*
Stock LT1 heads from 97 Z28. ~50k miles, assembled with stock valves and springs etc. $250+ shipping
Stock cam from 97 z28. $30+ shipping
New LT4 valvesprings/retainers/locks. $50 shipped
Superfueler for LT1. $200 shipped (also have 4 nearly new 42lb Lucas injectors ill include for another $80. the superfueler needs 3 injectors) *SOLD*
passenger airbag from 95 firebird. $100 shipped
New MSD pro billet distributor for SBC/BBC with built in Cam Synch. locked timing, adjustable collar. for use with crank trigger or FAST/DFI setup. $150 shipped
LT1 sport aluminum pedal covers for 4th gen with manual. painted black, say LT1 on them. un-used. $40 shipped
dn94blownz@aol.com
paypal accepted and preferred
Old Aug 31, 2004 | 06:08 PM
nfa's Avatar
nfa
Re: Several things for sale
Ill take the ripper shifter. Email sent.
Old Aug 31, 2004 | 06:22 PM
chevyguy3's Avatar
sorry, shifter is already spoken for
Old Aug 31, 2004 | 06:32 PM
nfa's Avatar
nfa
Ah.. ok. If the sale falls through, let me know. Thanks!
Old Sep 6, 2004 | 09:43 AM
chevyguy3's Avatar
also have a Mark Williams 3.5" MMC Duralcan aluminum driveshaft for a 4th gen f-body with TH400 and 12bolt/9" and rearend moved about .5"-.75" back from stock. $350 shipped (was $740+ shipping new)
Old Sep 6, 2004 | 09:45 AM
chevyguy3's Avatar
also a new solid roller for SBC/LT1. 269/284* @.050", .688/.673" w/ 1.6 rockers, 114LSA, 110ILC, .930" base circle
$170 shipped
Old Sep 7, 2004 | 05:15 PM
chevyguy3's Avatar
and a Vortech Maxflow "Race" bypass valve. in good shape, blue anodized version, flange included. $130 shipped
Old Sep 7, 2004 | 05:37 PM
Jason Short's Avatar
Sent mail Darren.
Thanks, Jason
Old Sep 7, 2004 | 05:44 PM
chevyguy3's Avatar
replied
Old Sep 8, 2004 | 07:26 PM
LTHL_LT1's Avatar
Is the camshaft still forsale?
Old Sep 8, 2004 | 07:28 PM
chevyguy3's Avatar
the stock LT1 cam, or the solid roller? and yes they are both still for sale
Old Sep 8, 2004 | 07:31 PM
LTHL_LT1's Avatar
ya the solid roller lifter is the one im interested in........you still have cam card & what brand is it? or is it custom?
Old Sep 8, 2004 | 07:32 PM
chevyguy3's Avatar
custom that was done for Nu-tek, i have the spec sheet from them. im pretty sure its a Cam Motion grind, but i would have to dig it out and take a look to double check. if its not Cam Motion, then its Comp Cams
Old Sep 8, 2004 | 07:53 PM
LTHL_LT1's Avatar
sorry for 20 questions I just need to make sure this cam is what I need before I buy it from you. What is the RPM Band.......Max RPM
Old Sep 8, 2004 | 08:24 PM
chevyguy3's Avatar
will depend on the combo, but will need to spin well past 7000 pretty much no matter what its on. would be suitable for trapping near 8000 on a 383/396, probably shift around 7500
