Leak from under dash
Old Aug 29, 2004 | 06:40 PM
Black1996Z28's Avatar
Exclamation Leak from under dash
Yesterday i noticed that under the dash on the passenger side water was beginning to puddle up on the floor mat. After taking a closer look it seems as if the car is leaking from under the dash behind the center console. Does anyone know what this may be and has anyone encountered this before? Any and all help is appreciated.
Mike
Old Aug 29, 2004 | 06:49 PM
Terran2k's Avatar
Re: Leak from under dash
seen this alot, usually its a leaking heater core
Old Aug 29, 2004 | 06:50 PM
RamAir95TA's Avatar
Mike
That's a definite indicator of a bad/leaky heater core.
How would that be fixed? Or should i just take it to the shop?
Old Aug 29, 2004 | 06:55 PM
Terran2k's Avatar
have some time on my hands, so i did a search (helpful feature by the way) and came up with this....
http://web.camaross.com/forums/showt...ce+heater+core
Old Aug 29, 2004 | 07:02 PM
Thanks for your help. Seeing a puddle on my floor kinda startled me last night. Would it still leak if i was driving without the AC on? Where can i get a new heater core also?
Old Aug 29, 2004 | 07:36 PM
Two good possibilities. Heater core or the a/c condensate drain is clogged. Was it water or coolant that was puddling?
The heater core is still pressurized no matter if the heat or a/c is on, so if it has a leak, it's gonna leak. You should be able to get a core at most auto supply places.
Old Aug 29, 2004 | 08:24 PM
It seemed just like water to me and my dad.
Old Aug 29, 2004 | 10:56 PM
slayer6x6's Avatar
Sounds more like the evaporator drain is clogged. Im not sure what the heater box looks like on the f bodys, but Ive seen the water also get into the blower motor so be careful of that.
Old Aug 30, 2004 | 08:36 AM
stereomandan's Avatar
It's the evaporator hole that is plugged. I had this same problem this spring. If you look at the black plastic casing the under the hood where the AC lines enter the car, there is a hole underneath that. You can only see it from under the car. It's on the passenger side, near the firewall. It's hard to see. Get a flashlight and a long screwdriver and just poke into that hole. When I did this, all sorts of water started pouring out on me. It was clogged. I had water on my passenger floormat just like you before I cleaned out the hole. It's been great ever since.
Shoebox has a picture of it somewhere I think.
Dan
Old Aug 30, 2004 | 10:08 AM
Dan
Pic here
Solo2
Jan 1, 2021 02:23 PM
Magenta_Hearts
Mar 29, 2017 08:54 PM
Scorch1
Jun 30, 2015 11:24 PM
Jun 19, 2015 01:34 PM
Brake_L8
Jan 20, 2015 09:44 AM
