K&N CAI 4 LT1 Question
Old Aug 24, 2004 | 03:02 PM
sharpe's Avatar
When I see people's K&N cold air induction system, it looks like two metal pipes that go from the MAF to under the car. But, when I go to K&N's website, or to www.thunderracing.com, their FIPK just looks like a little black 'L' shaped piece of plastic with a filter on the end of it. What do I need?
I want shiny pipes!
Old Aug 24, 2004 | 03:13 PM
Re: K&N CAI 4 LT1 Question
Sounds like you may be looking at pictures of the SLP CAI... two metal pipes. The GMPP intake is similar.
http://www.slponline.com/view_produc...RTNUMBER=21014
Old Aug 24, 2004 | 03:14 PM
Camerone222's Avatar
I dont know if K&N makes the "shiny" pipes you are looking for, but SLP does, but it will cost you.
Cameron
Old Aug 24, 2004 | 08:22 PM
unvc92camarors's Avatar
i would stay away from slp since the metal could hold heat in more=less performance
probably negligible and the added weight of it is negligible also but...
yea, the k/n is just a plastic piece of tube
the filter is supposed to flow 700 cfm, while the tubing can flow 1300 or so cfm
that's why you see some guys (eventually) replacing the filter with a different one (which some need modified work to the splash guard, etc.)
Old Aug 24, 2004 | 08:47 PM
Ace_437's Avatar
The SLP unit doesn't hold in any more heat, and looks 100 times better than the plastic K&N setup. The prices should be about the same, so if you like the look of the SLP, go for it. I'm glad I did.
Old Aug 25, 2004 | 04:47 PM
you sure about the heat thing?
once again, i say it's very negligible unless you're looking at every last ounce of power, but wouldn't the metal tend to hold the heat in more than the plastic?
just curious
Old Aug 25, 2004 | 05:42 PM
Its not a matter of "holding in heat". Its a matter of the thermal conductivity of the plastic vs. the thermal conductivity of the metal, and which one allows the heat from the engine compartment to flow through it into the moving air on the other side. In general, I would think that the metal has a higher thermal conductivity than the plastic, but you also have to take the relative thickness of each material into consideration. Put a little insulation around either of them, and they will not heat the air much at all.
Old Aug 26, 2004 | 01:09 AM
Ace_437's Avatar
just curious
The front of my motor doesn't get real hot. Actually not hot at all. Feel free to come over and feel the SLP unit if you like. Basically there's no difference between any of the CAI kits (aside from the G2), so get whatever you think looks the best.
Old Aug 26, 2004 | 01:15 PM
i'll have to check my buddy's z next time then
he's got it and i agree, it looks nice
Old Aug 26, 2004 | 02:20 PM
sharpe's Avatar
Where is a good (read: cheap) place to get a complete SLP CAI kit? Post linky, please.
Old Aug 26, 2004 | 03:05 PM
Ace_437's Avatar
$209
I got mine at:
http://www.slponline.com/view_produc...RTNUMBER=21012
You might be able to find it a little cheaper, but probably not much. Plus their service and shipping was fast. I think I had it within a couple days.
Old Aug 26, 2004 | 04:04 PM
sharpe's Avatar
Old Aug 26, 2004 | 04:30 PM
sharpe's Avatar
I got mine at Thunder Racing (though they didn't have it listed on their website) because I had to get plug wires at the same time. It was about $10 cheaper anyway.
Looks like I'll have to be changing my sig! No longer "Bone Stock!"
oldschool
Feb 9, 2016 09:21 PM
Killer94z
Jan 13, 2015 12:06 PM
cmdeshon
Dec 27, 2014 10:06 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Brad 97z
Aug 10, 2002 09:58 AM
