ES poly trans mount Q...
Old Aug 20, 2004 | 03:21 PM
2Fast94TA's Avatar
i just installed the poly mount and noticed the mount raised the transmission up. when driving around below 60 is not that bad, but around 70 on the interstate is terrible. can i just make shims to lower the transmission mount to stock setting? if so how thick should i make them?
Old Aug 26, 2004 | 12:20 PM
sallmon's Avatar
Re: ES poly trans mount Q...
I have the exact experience with my 95 Z28. It is obnoxious enough that I am seriously considering yanking it out and going back to the "break every 6 months" OEM mount. The ride is adversely affected at EVERY speed, but horrible at 70+ MPH.
Old Aug 27, 2004 | 12:16 AM
Jay-Roll's Avatar
I bet it probably just raised the tranny back up to stock height your just experiencing the heard of extra vibration. The stocker probably settled so much over time and deterioration that's why your thinking the new one raised it. I personally never noticed a difference in vibration, but if you don't like it you can switch to an LS1 mount. About in the middle between a stocker for an LT1 and a Poly one as far as firmness and reliability.
Old Aug 27, 2004 | 06:31 AM
JWBerk94Z's Avatar
Same problem here. My car is an M6 and anything over 70 has a really wierd vib. I bought a stock one from advanced for $10 and it is going back on there. I don't have the stock torque arm mounted to the tranny though, so that will make my cheap mount last.
Old Sep 2, 2004 | 08:28 AM
FireHawk409's Avatar
Oh man my poly viabrates. I didnt take the people who complained about it seriously. Yeah i have my adj t/a at around -4, might go up to -3 BUT when i had the stock one with the same settings it did NOT viabrate. Yesterday i got my car up to 120 and i thought my passanger seat was going to fly out my window along with my center console.
I do have an idea. I have the ES poly mount which gives you the mount and a metal bracket. So now you basically have the metal from the mount mated to the metal bracket then to your tranny. So thats basicaly metal to metal. What do you guys think if i sprayed that metal bracket with something like that rubber undercoating spray? I also have dynomat layin around maybe i can put it between the tranny and metal plate, and between the plate and mount. Any opinions?
Old Sep 2, 2004 | 08:54 AM
Ponyhntr's Avatar
HOw long have you guys had your ES mounts installed? The reason I ask is the mount needs some time to 'break in'. After a couple weeks you should notice the vibrations going away. All three of the cars I have had those mounts in did the exact same thing, but then went away over time.
Old Sep 2, 2004 | 09:29 AM
IllusionalTA's Avatar
Your driveshaft is mostly causing most of the vibration.. try rotating the shaft 180 deg. and see if it get's better.. Vibe is one of the sacrifice's involved w/ the poly mount's.. worth the security IMHO..
Old Sep 11, 2004 | 08:51 PM
LiT1_up's Avatar
Don't install the metal plate thats included with the ES mount.
Old Oct 1, 2004 | 10:27 PM
apick42's Avatar
Wink Re: ES poly trans mount Q...
That works or like you thought you can sim the cross member down
to allow for the hight of the bracket and yes the bracket causes the
angle at the end of the trans to be incorrect.
Old Oct 6, 2004 | 10:07 PM
CamaroSS30thAnn's Avatar
i just bought and ES (i guess 'energy suspension') poly mount. should i or should i not put teh bracket on ?, i really do not want teh vibration or to do it twice, i mean i can deal with a little vib but i dont want agressive vibrations
also y do they sell teh bracket if not needed?? different applications??
thanks bobby
Old Oct 6, 2004 | 11:48 PM
Valkyn71's Avatar
My car had a broken stock mount when i bought it, i put a poly one on and dont notice excessive vibration over 70mph...its an Fbody so of course your gunna get some rattleing and stuff but its hardly noticable for me.
Old Oct 7, 2004 | 02:29 PM
thanks man
Old Oct 7, 2004 | 04:41 PM
spgino's Avatar
I noticed a lot more vibration from the drivetrain.. i also have the ES poly mount in my 99 LS1.. will it get better, or should i take the metal 'spacer' out and reinstall it??
btw.. love the way my car responds now... i didnt know then (when i bought my car 4 months ago that my tranny mount was broken).. wow what a difference
Old Oct 7, 2004 | 06:17 PM
sallmon's Avatar
Exclamation Re: ES poly trans mount Q...
The "spacer" is actually a pre-load plate and should NOT be discarded.
Check your flywheel for cracks or missing weights; if it's OK, check your driveshaft ( a VERY common problem in these vehicles ).
In my case, a new flywheel ( about $60 ) absolutely cured my problem. Took about an hour, start to finish.
Rde Bandit
Mar 21, 2015 10:17 PM
Jason Short
Jan 19, 2015 06:34 PM
x7x7
Aug 15, 2002 06:49 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
