Gauging Interest on Value of 97 Camaro Drag Race Car
Old Aug 19, 2004 | 01:55 AM
SICK SS's Avatar
A business oppurtunity of a lifetime has presented itself to me and against all my will, I will be selling this car.
I will also entertain trades as well.
1997 Camaro Z28 Stock Style Suspension Racecar
NMCA Drag Radial or EFI Legal
PSCA Limited Street, True Street, or Wild Street Legal
PRO/NSCA Xtreme Street Legal
LS1Tech Racing Series Legal
Exterior is White – Chassis Only Has 24k Miles
Complete Body.
Car will be without Motor or Transmission
Paint is in Excellent Shape.
T-Tops
Tinted Windows
Interior is Charcoal Gray – Complete except Carpet and Headliner
Original Hound’s-Tooth Rear Seats Included
M6 Console
Chassis:
- Custom Brad Hadman Progressive Metal Craft ChromeMoly Rollcage Certified to 7.50 till 2-06
- Cage Goes Through the Firewall, Through the Strut Towers and Up to the Frame Horns
- PA ChromeMoly K-Member
- PA ChromeMoly A-Arms
- Tubular ChromeMoly Sub Frame Connectors w/ Additional Boxed Bracing to Inner Pan
- (New) Pinto Style Manual Steering Rack w/ adjustable Bump Steer Ends
- Glasstek Dzus Fastened 4" Cowl Hood, Painted to match the car
- (New in box) Ed Quay Sheet Metal Pro Strut Wing
- Cowl is cut and molded to Firewall
- All Engine Bay Holes filled, Engine Bay Painted Gloss White like Rest of Car
- Heater/AC hole in firewall Covered/ Welded/ Painted to be One Piece w/ Firewall
- (New) 2 Sparco Racing Seats, with Sliding Brackets
- Stroud Parachute w/ Removable Parachute Mount
- (New) Stroud Parachute Release Cable
- (New) Aerospace Drag Brakes on All 4 Corners
- Converted to Manual Brakes
- (New) Wilwood Manual Master Cylinder
- Solid Tubular ChromeMoly Motor Mounts for LT1/SBC/BBC
Suspension:
- Wolfe Racecraft ChromeMoly Torque Arm
- Wolfe Racecraft Solid Anti-Roll Bar
- Custom 76" Pro Stock Type Wheelie Bars (Powdercoated Black)
- Custom Easy Adjustment Spohn ChromeMoly Spherical-Rod End Lower Control Arms
- (New) ChromeMoly Rod End Adjustable Pan Hard Rod
- (New) QA1 Coilover Front Shock/Spring Package
- (New) QA1 Rear Shocks
- OEM Z28 Convertible Rear Springs
Rear-end:
- Custom Narrowed 9" Rear-end
- (New) Strange Ultra Case w/ a 3.250" pinion bore and a 35 spline aluminum spool and 12 bolt pinion support.
- Lamb style racing flanges.
- (New) 3.89:1 Ring and Pinion Set / 9310 Steel
- (New) Strange Aluminum Spool and 12 Bolt Pinion Support
- (New) Moser Gundrilled and Flange Lightened 35 Spline Axles
- (New) Aluminum 35 Spline Strange Spool
- Entire Rear End Powder Coated Black
Electrical:
- (New in box) Painless Wiring 12 Circuit Streetcar/Drag Race Wiring Harness -
- (New) Autometer 2 5/8" Ultra Lite Aluminum Gauges (Oil Psi, Fuel Psi., Water Temp, and Voltage) –
- Autometer ProComp 5” Pedestal Mount Tach w/ Recall, 9000 RPM
- Gauges Mounted in Factory Location in Custom Carbon fiber Panel, Behind Factory Glass
- (New) Rear Mounted Aluminum Sealed Battery Box
- (New) Flaming River Push Off Battery Master Switch
Fuel System:
- (New) Charged Air Systems Fabricated Aluminum Fuel Tank w/ Rear Sump
- (New) Aeromotive Billet Filters Pre-Pump and After Pump
- (New) Product Engineering Y-Block
- (New in box) 20feet of each> -10AN Supply Line, -8AN Return Line
- (New) – 2 feet -12AN Sump Line
- Earls and Aeroquip Fittings and Adel clamps
Price reduced: $16k
Old Aug 19, 2004 | 06:45 AM
94 guy's Avatar
Re: Gauging Interest on Value of 97 Camaro Drag Race Car
how much for the car? do you know a weight?
Old Aug 19, 2004 | 07:49 AM
SICK SS's Avatar
That's why I posted this thread. I want to get some professional opinions on what the car would sell for. The car will come without a motor or transmission.
With a SBC, LT1, or LS1 motor and transmission, the car would weigh approximately 2700-2800 lbs without driver. Maybe less, I haven't had it on a scale the way it sits.
What do you think?
Old Aug 20, 2004 | 12:10 AM
SICK SS's Avatar
To the top.
Old Aug 21, 2004 | 09:54 AM
carbed93Z's Avatar
KILLER CAR!!! Have you had any reasonable offers on it yet?
Old Aug 21, 2004 | 11:30 AM
SICK SS's Avatar
Not yet! Still waiting for that right price or trade.
Old Aug 22, 2004 | 06:05 AM
SICK SS's Avatar
To the Top
Old Aug 22, 2004 | 10:01 AM
TN94Z's Avatar
How would you want to trade for a 94 z28 highly modded??
Old Aug 22, 2004 | 11:50 AM
spraytheway's Avatar
I have a similar car and it weighs 2800lbs without me in it. I would have to think that although there is no ignition in the car it is worth $17-$22000 rolling. The parts and labour are there. Its moly not a peice of crap. To make it legal past 2006 you will have to do a couple of floor bars. Not a big deal. I am in the same boat. Put it on racingjunk and National dragster. Does it have lightweight brakes and manual rack?? Really?? Even without these things its still worth $15 000 on a bad day. JMHO.
Old Aug 22, 2004 | 12:00 PM
SICK SS's Avatar
Send me some fullsize pics and a descriptive list of mods to kgrubbs@satx.rr.com
Old Aug 22, 2004 | 12:10 PM
SICK SS's Avatar
Yes it has Aerospace brakes all around and a Aerospace pinto style manual rack. Thanks for the info and response!
Old Aug 22, 2004 | 04:16 PM
SICK SS's Avatar
I've also posted this over on ls1tech.com:
http://www.ls1tech.com/forums/showthread.php?t=206149
Old Aug 25, 2004 | 05:33 PM
SICK SS's Avatar
still available
Old Aug 25, 2004 | 06:26 PM
WhtLT1's Avatar
Would u trade for another white camaro with a cam?
Old Aug 27, 2004 | 03:32 PM
SICK SS's Avatar
Send me some good pics: kevinsgrubbs@hotmail.com
What year? Stock motor?
