Left turn signal doesn't blink.
Old Aug 18, 2004 | 06:42 PM
ScreamnChicken's Avatar
When I put the left turn signal on, the light comes on, but it won't blink. However, when I but my hazards on, all the lights blink. Any ideas.
Old Aug 18, 2004 | 07:29 PM
red96taA4's Avatar
Re: Left turn signal doesn't blink.
check relays. its happened to a friend of mine...but im not sure what the reasoning was, ill see if i can find out.
Old Aug 18, 2004 | 09:18 PM
I replaced all of the bulbs, no luck...I checked the flasher, no luck...I wouldn't think a fuse would just cause half the light to not turn on. I found out that when I put just the lights on, all the lights work. However, when I put the blinker on, or put the breaks on, the 2nd light from the outside goes completely dead, so I am thinking it is a wiring problem or something???
Old Aug 20, 2004 | 10:29 AM
blind527's Avatar
i have brought my car in so many times to be looked at for this "electrical problem."
at first my right fog light would go on and off, and my right blinker wouldn't work and my left one would. after 2 times of bringing it in, everything worked for about 3 days, and after that my left fog light when out and NO blinkers work. the only time a blink DOES work is if i put my headlights on, then about half of my lift fog light goes on, and my right blinker SOMETIMES works. its REALLY pissing me off.
if i bring it in *keep in mind its under warranty* what should i tell them???? should i just be like rewire everything?!?!?
stangspank
Nov 13, 2015 01:02 PM
CaRParts102
Dec 6, 2014 08:45 AM
vinnyxgunz
Aug 28, 2002 09:41 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
