HEI rebuild problem
Old Aug 15, 2004 | 01:05 PM
noc_81's Avatar
HEI rebuild problem
I ripped apart two HEI (non-ecm), cleaned, polished, and tested every component, but there is still one problem I have before I can put them back together. I noticed when I pulled them apart, I noticed under the pickup plate, and under the felt washer and its holder, the area around the distributor shaft bore, was filled to the brink with some sort of reddish clay-like substance.
I have no idea what this stuff is, and wonder if it is crucial. anybody...?
Old Aug 15, 2004 | 04:09 PM
Dave89IROC's Avatar
Re: HEI rebuild problem
I think that is the remains of the OE grease
Old Aug 18, 2004 | 04:19 PM
noc_81's Avatar
Would it hurt to fill it up with grease? If not, what type?
Old Aug 18, 2004 | 05:00 PM
slayer6x6's Avatar
I would use a di-electric grease or a silicone paste.
Old Aug 22, 2004 | 04:25 PM
noc_81's Avatar
silicone paste... as in rtv sealant?
Old Aug 22, 2004 | 11:14 PM
slayer6x6's Avatar
Not the silicone sealant, silicone paste is a grease/lube that can be used just about anywhere. I use it for probably about a million and one things at work.
Sergio
Jan 27, 2016 04:27 PM
dfarr67
Apr 10, 2015 07:44 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
