3.48 vs 3.50
Old Aug 12, 2004 | 06:02 PM
Schurters LT1's Avatar
3.48 vs 3.50
I was taking to an eng builder and we started talking about what crank i was going to use of my rebuilt (stock) and he said what he dose is take the crank and turn it into a 3.50 stroke from the 3.48 OE stroke...
What are the Pro's and Con's of this
What affect on the rods/length will this have
Are piston changed here as well.
thx
Old Aug 12, 2004 | 06:57 PM
llafro's Avatar
Re: 3.48 vs 3.50
Not exactly advanced tech.
It will make a difference of 1.85 cubic inches. Not enough to make any difference. You get more of an increase from a normal rebuild, in which the cylinders are bored 0.030" more than stock (4.030" bore). That results in an increase of 5 cc, to give a 355 ci engine.
Maybe what he was talking about was a 3.75" stroke, which would be a 383? Now that's worth the trouble.
BRAD
Old Aug 12, 2004 | 07:10 PM
OldSStroker's Avatar
Re: 3.48 vs 3.50
thx
The .020 longer stroke gives you about 2 more cubic inches, but it also raises the piston .010 in the bore. If the block hasn't been decked, and the pistons are down in the hole, it should be ok and you'll get some slight compression increase, so power will be up a little. You shouldn't have to change rods and stock replacement pistons should be ok unless the block is decked a lot. If the rebuilder has done many he knows (or should know) the things to watch for.
As long as you have to grind the crank undersize anyway, there's not a lot of downside, except perhaps a slightly higher octane requrement if you are now boderline. Around here 2 octane points cost $.10 per gallon.
Would I pay extra to have it done? Probably not.
My $.02
Old Aug 13, 2004 | 02:32 AM
AdioSS's Avatar
West South Central Moderator
Re: 3.48 vs 3.50
My $.02
On a positive note, the slight increase in compression will also give a slight increase in fuel economy
Old Aug 17, 2004 | 12:57 PM
ME Leigh's Avatar
Re: 3.48 vs 3.50
It is a good idea, he sounds like a good eng builder that knows what the hell he is doing. It will give you a more optimum quench distance, which is all around good.
blac94Z
Nov 24, 2014 07:12 PM
tooljunkie
Aug 3, 2004 12:12 AM
n2oblkz
Advanced Tech
Jul 9, 2004 06:55 AM
LewisW96
Parts Wanted
Jun 24, 2004 01:40 PM
Acct 23749
Parts Wanted
Nov 4, 2003 12:47 PM
