M6 & Rearend oil change
Old Aug 7, 2004 | 12:26 PM
SantaCruz163's Avatar
I'm going to be changing the oil in my tranny and rear end today and I was wondering what kind of oil to use. I know that the T56 calls for ATF fluid (god knows why ) what band is recommended, I don't want anything too too expensive. As for teh rearend, what weight gear oil do I need and what brand is recommended? Whats all the talk about adding limited slip 'additive' is that really needed?
Old Aug 7, 2004 | 01:04 PM
unvc92camarors's Avatar
Re: M6 & Rearend oil change
yea, just use some quality atf fluid in the m6
just change it at the required interval and you'll be fine, no need to go overboard putting expensive stuff in there as long as you change it when it needs to be done
4 qts is needed for this
for the rear end, 80w-90 is what is reccommended in the owner's manual
just pick something and put it in there also
and the limited slip additive is a MUST
just go to your nearest dealer and pick soem up, they'll know exactly what you're talking about, it's about 8$
you'll need 2 little bottles of fluid for the rear end and you'll be able to get about 1.5 to 1.75 in there
have you checked brent's site on this lately?
http://www.bfranker.badz28.com/fbody/lubeoil.htm
grabbem88
Mar 18, 2015 01:25 PM
Dark Zeiro
Mar 11, 2015 07:15 AM
jj71787
Jan 31, 2015 10:20 PM
Sandersen511
Jan 13, 2015 03:49 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
