Key Stuck in Ignition
Old Jul 29, 2004 | 03:03 AM
NightWindDriftr's Avatar
[sorry-in-advance if this has been addressed already]
sometimes, when I shut the car off, my key won't pull out of the ignition. it won't turn to the "remove key" position, and if I apply pressure my car makes a beep. I'm assuming that it's the PassKey system kicking in for some reason unknown. if I let the car run for a few minutes the key usually comes right out. any ideas on what's going on?
Old Jul 29, 2004 | 08:01 AM
Red96Lt1's Avatar
Re: Key Stuck in Ignition
The only thing that I can think of is that the little resistor thing is moving in and out of your key. Is it loose?
Old Jul 29, 2004 | 10:02 AM
TraceZ's Avatar
That does not sound like a pass-key problem. It sounds more like your ignition switch or its actuator rod are binding up on something.
Old Jul 29, 2004 | 10:27 AM
rncotton's Avatar
Had that problem in my 2001 Camaro. Dealer had to replace the ingnition switch. There was nothing wrong with the key. The switch itself had broken inside.
Old Jul 29, 2004 | 11:39 AM
Might be this.
KYWes
Jun 14, 2022 06:52 AM
surreybrad
Jul 5, 2015 10:36 PM
pimpinphil
May 30, 2015 04:20 PM
Dzmaro
Jan 25, 2015 10:39 AM
WipeOutXXL
Aug 5, 2002 09:27 AM
