tork converter, valve springs, cat-y pip & more
Old Jul 25, 2004 | 03:46 PM
5.7LT1Formula's Avatar
i thought i would post and see if anyone needs the following parts...
parts came off of a 95 Formula or were bought before i decided to go w/ a 383 stroker. All parts are good and were taken off because of my 383 build up.
i have:
stock Cat w/ y pipe guts of cat look great.
stock tork converter w/ 5,000 miles on it
Comp cams Double valve spring part#924-16 w/ 5,000 miles on them
includes retainters.
Specs: Seat Load: 125# @ 1.880''
Open Load: 315# @ 1.280''
Coil Bind: 1.200''
Rate(Lbs./In.): 317#
Set of 16
TPIS valve spring part #700-132 with 5,000 miles on them,
includes locks and retainers
Specs: Stock Diameter 1.270, coil bind 1.150 428lbs, miniumum running height 1.250 357lbs.
Water pump drive assembly that is bolted to the block under the timming cover.
Stock Crank, came out of running LT1 may need grinding.
I am open for offers i can email pictures though they may not be as great w/ my camera phone. My email address is ryanfree@onlyinternet.net ,I can accept paypal.
Old Jul 25, 2004 | 08:22 PM
Re: tork converter, valve springs, cat-y pip & more
ttt
DirtyDaveW
Mar 15, 2015 07:01 PM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Jul 4, 2005 05:00 PM
