Difference between shocks and struts
Old Jul 24, 2004 | 06:53 AM
Schmidt519's Avatar
I have a 00' Z28 and I think it has struts in the front and shocks in the rear, whats the difference between the two, and can you replace the two struts with shocks. Which are better shocks or struts?
Old Jul 24, 2004 | 08:16 AM
DJ_951's Avatar
Re: Difference between shocks and struts
The 4th gen 93-02 have a front shock not a strut anymore. Shock are better in theory....liked the way my IROC handled with struts in front.
Old Jul 24, 2004 | 09:20 AM
Dark Angel's Avatar
I would disagree. The 4th gen has struts up front and shocks in the rear. Basically a strut is a coil over design. A coil spring mounted around a shock. No, you can't usually replace a strut with a shock, since then you would need to find somewhere to mount the spring. This is a very common setup with struts in the front, due to space and pivoting for the steering. Alot of people actually try and convert to the coil over design on the rear.
Struts are a little harder to work with and change, since the spring is held at tension on the shock and you have to compress it to remove.
Old Jul 24, 2004 | 01:37 PM
Loony's Avatar
http://web.camaross.com/forums/showt...s&pagenumber=2
Old Jul 25, 2004 | 07:17 PM
DaddySS's Avatar
Well technically struts replace part of the spindle and turn as part of the steering assembly. 4th gens have a coil over shock but it's still a shock, not a strut.
mrwz28
Jul 8, 2015 09:11 PM
SergheiS
Jul 5, 2015 03:27 AM
timmy39120
May 2, 2015 05:12 PM
Magenta_Hearts
Mar 22, 2015 02:44 PM
DropTop91
22
Aug 8, 2002 10:53 AM
