throw out bearing bad??
Old Jul 23, 2004 | 08:25 PM
Roadart's Avatar
Hello all, I was wondering how you can tell if a throw-out bearing is bad.
When I start the car, I can hear a slight whine that goes away when I push in the clutch pedal.
I have also begin to notice a very small (about the size of a silver dollar) puddle under the trans (where it bolts to the engine). I thought it was oil at first, but I think its clutch fluid because I checked the master cyclinder and it was low (about 1/4 the way down).
I have the SLP Lightweight flywheel, SLP LT4 Clutch and PP /w throw out bearing. About 3000 miles on the clutch setup, and new Master/Slave unit from GM.
If I am leaking fluid, will that damage the clutch setup? The clutch doesn't slip, and I noticed the leak about a month ago but I don't drive the car often.
Thanks Guys,
Kevin
Old Jul 23, 2004 | 08:32 PM
RacingTiger04's Avatar
Re: throw out bearing bad??
that whine sounds very familiar, when i had a throwout bearing go out in my previous car (95 firebird 3.4 5spd) it whined really bad before it went completely out at which point it sounded like a banshee screaming whenever you tried to put it in gear. i dont remember any kind of puddles though, just the whining sound it made...
Old Jul 23, 2004 | 08:46 PM
Roadart's Avatar
Thanks for the reply RacingTiger. Its weird. sometimes it leaks, other times its fine. The whine isn't supernoticable... but its enough for me to notice it (I am super picky) I do have a light coating of clutch fluid on the tranny casing... but not enough to burn on the exhaust.
Thanks again.
Old Jul 23, 2004 | 08:48 PM
np, im picky just the same with my Z, it has a selectable 1st gear but the panel didnt show it, so i bought the panel that did but now the gears dont line up right with the notch for em... course they didnt before, desnt matter to me cause i can feel em out but im just that picky :-p. anyway good luck gettin that fixed
timmy39120
May 2, 2015 05:12 PM
Apr 16, 2015 09:57 AM
BigWil
Mar 29, 2015 12:24 PM
grabbem88
Feb 17, 2015 07:49 AM
HectorM52
Jan 30, 2015 11:08 PM
