Understanding flow characteristics
Old Jul 22, 2004 | 09:18 PM
Rodrigues's Avatar
I have an intercooler with the spearco 2-230 cores http://www.turboneticsinc.com/liquid.html, which spearco rates to 1500cfm. Now lets say I get a T88, which flows aprox 1700cfm... what happens? Seems like a lot of people are getting away with tiny intercoolers... heres a pic of mine.
http://kak.com/camaro/intercooler/DSCN0741.JPG
http://kak.com/camaro/intercooler/DSCN0740.JPG
Old Jul 22, 2004 | 09:45 PM
engineermike's Avatar
Re: Understanding flow characteristics
The intercooler will explode since there is nowhere for the extra 200 cfm to go. Just kidding.
I'm not sure if they're rating it based on restriction or cooling capacity. Either way, that's way bigger than the Vortech Aftercooler and people run 9's with that.
Mike
Old Jul 22, 2004 | 10:30 PM
Rodrigues's Avatar
Think its possible to push over 1,200 at the crank through an intercooler like this?
Mike
Old Jul 22, 2004 | 10:36 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
1500cfm is measured at a pressure drop (1.5 psi i believe). so if you try to flow more through it, you will get a greater pressure drop. 1500cfm is a nice size IC.
Old Jul 22, 2004 | 10:44 PM
Rodrigues's Avatar
Is the pressure drop usually pretty linear vs initial boost?
Old Jul 22, 2004 | 10:52 PM
Pressure drop is proportional to the square of flow. So, if you plan on flowing a TRUE 1700 cfm, then you could find the pressure drop by:
dP = 1.5 * (1700/1500)^2 = 1.93 psi
Old Jul 22, 2004 | 11:53 PM
Rodrigues's Avatar
According to the graphs of the t88 its able to push a peak of 120 lb min, so 120/.069= 1739 peak. Now lets assume a 2 psi drop. So the more pressure i push through, a larger percent is being lost to pressure drop. So even if I push exactly 1500cfm, im still losing 1.5 psi.... not too shabby only losing a half psi or so for 200 more cfm imo.
Formula Steve
Sep 19, 2023 08:31 AM
Novo
Jun 14, 2016 02:58 AM
4586
Sep 27, 2015 01:55 PM
tommalcolm
Sep 11, 2015 03:39 PM
Daluchman1974
Sep 11, 2015 06:12 AM
