When building a blower motor.....
Old Jul 21, 2004 | 10:02 PM
BLUE95ZZ's Avatar
Should block selection be an issue ive heard the vette blocks are 4 bolt main oem anything else different or should i just machine my 2 bolt block for 4?
Thanks Matt
Old Jul 22, 2004 | 02:19 AM
n2oblkz
Guest
Posts: n/a
Re: When building a blower motor.....
I'm in the process of getting things together to do a 355 blower motor. I just purchased a set of bare AFR LT4 210cc heads. I am going with the Eagle forged rotating assembly. They have a good deal if you check their site. I'm going to go 4 bolt splayed on mine, just to be safe. I don't think that it is absolutley necessary but I would rather be safe, especially with a blower motor. I have seen many discussions about 4 bolt mains and many people say that you would be hard pressed to find a motor that let loose because of only being a 2 bolt block, and I would agree. A buddy of mine just finished his 355 blower car and it only has a 2 bolt block. The motor was not built right last time around and the motor absolutely went. You could see where the main caps were moving around and lifted the studded heads but they did not let go. That was even with the stock crank that he just put back in the new motor. I think that you would be fine with a 2 bolt but if you are like me and are paranoid and always think of the worst, then go 4 bolt. BTW the vette 4 bolt blocks are not splayed, so they are not as strong. I would rather have an LT1 bock with 4 bolt splayed, that's what I'm going to do.
Old Jul 22, 2004 | 05:53 AM
Highlander's Avatar
Both ways you are going to be ok as long as you have a 4 bolt in... I dont like the splayed caps, just straight where the block has more meat...
Old Jul 22, 2004 | 06:40 AM
engineermike's Avatar
My block was converted for 4 bolt straight. The quality of the machine shop is more important than the angle of the bolts.
Old Jul 22, 2004 | 06:41 AM
Highlander's Avatar
Exactly... hey mike.. visit my forum.. check it out
Old Jul 26, 2004 | 10:39 PM
BLUE95ZZ's Avatar
Hey thanks Guys
Matt
Old Jul 27, 2004 | 08:31 AM
Acct 23749's Avatar
Originally Posted by BLUE95ZZ
Hey thanks Guys
Matt
I also had my 2 bolt converted to a straight 4 bolt...
there are arguments and opinion for each...i personally like the straight better cuz i was able to use studs on all 4 bolts, like highlanded said, there more "meat" in that part of the block etc...
Old Jul 28, 2004 | 10:36 PM
BLUE95ZZ's Avatar
Thanks kenny
Novo
Jun 14, 2016 02:58 AM
RUENUF
Mar 13, 2016 03:37 PM
CARiD
Sep 30, 2015 05:44 AM
pepon214tx
Sep 20, 2015 04:48 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
