LT1 4 bolt / Eagle rods / Lt4 intake / misc parts
Old Jul 20, 2004 | 01:21 PM
OrionSPL's Avatar
I still have the following items for sale:
LT1 4 bolt bare block - this block has the endcaps. The block has been bored .030 over and was run for less then 3000 miles. It has a sleeve in #7 and a piston broke apart in #5 but it is usable. The cylinders look pretty good and at most they would need to be honed. This was used for a 383 stroker LT4 setup. Asking $200 and needs to be picked up
Eagle H-Beam ESP 6" rods - these rods have less then 1000 miles on them and are in perfect condition asking $350
LT4 intake - This is an GM LT4 intake with distributor hole drilled in the rear. This hole can be plugged up using a cap from the LT4 carb intake if not wanting to use a rear mount distributor. Asking $200
Canton LT1 high capacity oil pan. This pan has less then 3000 miles use and just needs to be cleaned. Asking $150
LT1 Extreme duty timing kit - Less then 3000 miles use. Asking $150
OBDII computer with LT1 Edit and cable asking $300
Crane hydraulic roller lifters $75
If there are any questions please email them to OrionSPL@comcast.net. Thanks!
Old Jul 20, 2004 | 05:41 PM
Black6SpdTA's Avatar
Re: LT1 4 bolt / Eagle rods / Lt4 intake / misc parts
Email'ed you about the block...
-Corey
Old Jul 20, 2004 | 10:29 PM
TheBiz's Avatar
"LT1 Extreme duty timing kit - Less then 3000 miles use. Asking $150"
Would this hold a CC306 cam? Would I have to switch to electric water pump with this? If not, let me know. I have a stock LT4 timing kit, now but I want something heavy duty cause of the cam.
Let me know by e-mail,
BIZ
Old Jul 25, 2004 | 12:41 PM
pillagenburn's Avatar
LT1 edit - is it OBD1 or 2?
thanks
Old Jul 25, 2004 | 07:32 PM
1984camaroz28's Avatar
how many miles and how much lift are these good till
Old Jul 25, 2004 | 09:32 PM
OrionSPL's Avatar
This is an OBD2 LT1 edit. I also have a Meziere electric water pump with LT1 housing that has been plugged. Asking $200 for it.
Old Jul 25, 2004 | 09:43 PM
Old Jul 25, 2004 | 09:48 PM
OrionSPL's Avatar
They have less then 3000 miles on them. The part number is 10530-16, I'm not sure what lift they are good too. Have to check it out.
Old Jul 25, 2004 | 10:03 PM
got any pics
Old Jul 30, 2004 | 09:54 PM
xtremetrans's Avatar
Interested in canton oilpan. E-mail me at xtreamtrans@yahoo.com if you still have it.
LeftoverChinese
Jan 14, 2024 03:03 PM
Catmaigne
Dec 25, 2014 12:16 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
