Fuel for nitrous?
Old Jul 19, 2004 | 02:16 PM
Billet ss's Avatar
Fuel for nitrous?
Can a heads and cam car run a 150 wet shot with just a intank pump upgrade?
Old Jul 19, 2004 | 04:13 PM
mrr23's Avatar
Re: Fuel for nitrous?
well i run 200 shot on a stock ls1. i actually had to lean up the n2o it was so rich. http://www.stealthram.com/familypics...ocutoutsae.jpg
Old Jul 19, 2004 | 07:03 PM
Billet ss's Avatar
I'm more so talking about the lt1 cars?
Old Jul 19, 2004 | 07:19 PM
mrr23's Avatar
ok. now that you cleared that up here goes. i used the nos05176 125 dry kit on my 94 z28. no heads and cam. the kit comes with an inline fuel pump to add the extra fuel flow requirements needed. what you need, if you don't already is a dyno with a/f readings to see where you are at. then determine if it can go from there. by the way it went from 13.60 to 12.24 @ 113.90. this was an auto with 2.73 gears to boot.
Old Jul 21, 2004 | 09:17 AM
COMNBYU's Avatar
If you've got a heads/cam car, you need to find out where you are now with a/f, as was said. You should be fine with a inline FP and a FPR. But it will take some tuning to find out where the best setting will be...
Jon
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
alphaauto
Jan 23, 2015 07:42 AM
bandit383lt4
Dec 21, 2014 09:12 PM
