Water injection working great and for cheap
Old Jul 17, 2004 | 05:56 PM
Alvin@pcmforless.com's Avatar
Its a shame that the alky controllers out there are so expensive.
I got a standard PWM controller capable of 25amps for freakin pennies. I used a TPS switch to activate the system and I'm thinking about adding a 0-22psi map sensor (~$5 from digikey) to give it some progressive control.
I've also got a simple darlington switch i plan on using it to control a nitrous soleniod that will get a signal from the stock injector driver..
That way the whole system is progressive with boost, has controllable pressure, and is linear with the stock fuel system.
Old Jul 17, 2004 | 09:31 PM
96TurboTA's Avatar
what controller r u using, and where did u get it?
Old Jul 17, 2004 | 09:41 PM
i made it
Old Jul 20, 2004 | 06:44 AM
v7guy's Avatar
Re: Water injection working great and for cheap
I'm not even familiar with what a PWM controller is LOL!! want to enlighten me?
Old Jul 20, 2004 | 09:29 AM
Instead of cutting voltage to the pump it runs it in a duty cycle way..
You get alot better control.
Old Jul 20, 2004 | 11:11 AM
carnutz's Avatar
Well now you've got us interested so spill the beans, HOW did you build it, where did you get the parts, etc......
Old Jul 20, 2004 | 12:26 PM
I told you what it is, Just do a search for a schematic for a PWM controller.. anything about 20 amps is fine.
oldschool
Feb 9, 2016 09:21 PM
Jazsun
Dec 29, 2014 12:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
Roshambo
Sep 4, 2002 11:25 AM
Paulberg
Jul 26, 2002 11:35 AM
