Removing rear bumper?
Old Jul 12, 2004 | 10:08 PM
Tattooedlife's Avatar
How much trouble is it to remove rear bumper? Don't realy need to remove it just snug it back up. Its not lined up good, just need to straighten it back up. Is this going to be a pain to do?
Old Jul 13, 2004 | 01:20 AM
Jay-Roll's Avatar
As long as your not removing it completely you should be alright. All you have to do is remove the tailights(2 black plastic wingnut things each) remove the 4 or so bolts keeping the center section(part that say's CAMARO). Then you can get to all the tabs on the top part of the bumper. There are also a bunch of tabs on the bottom and one screw in each wheel well. Oh also 2 nuts on each side for the side of the cover(would be under the spare on the passenger side, and similar spot on drivers side). Loosen anything up you think you need to and adjust and tighten as needed. Then reverse the process. I tried removing mine completely a while back and couldn't get the bastard to come off. I ended up cracking my clear coat a little bit so I called it quits. I tried very softly forever. I was doing it for a different reason though, and changed my mind after all that crap.
CARiD
Feb 9, 2015 09:35 AM
CaRParts102
Dec 6, 2014 08:45 AM
siguy
Nov 27, 2014 10:07 AM
Z28STYLE23
Aug 17, 2002 07:40 PM
