Changing rear brake pads?
Old Jul 11, 2004 | 02:14 PM
Tattooedlife's Avatar
I took off my rear wheel and was going to change out my rear pads, but notice it had what i guess was the parking brakes attached to them which have to be removed before you can get to the bottom caliper bolt. Does anyone have a step by step on this. The guy gave me new rear brake pads and spark plugs when I bought the car, I guess thats why he didn't change the pads. I'm wanting to paint my calipers, and figured I would change the brake pads at same time.
Old Jul 11, 2004 | 02:59 PM
CamaroBoy96Z28's Avatar
You dont have to disconnect the parking brake cables. If you're just changing pads, you can undo the top caliper bolt and just flip the caliper back. Then swap out pads.
Old Jul 11, 2004 | 03:10 PM
96lt1Camaro's Avatar
Exactly what he said. Unbolt top bolt and flip caliper back.
Old Jul 11, 2004 | 03:37 PM
Man, I wish I would have tried that last week when I had the wheel off. Ha, Ha
Old Jul 11, 2004 | 05:36 PM
n2ceptor's Avatar
Be careful not to forget or damage the H-shim...
Old Jul 11, 2004 | 05:40 PM
H-shim?
Old Jul 11, 2004 | 08:12 PM
n2ceptor's Avatar
# 17.....
http://shbox.com/1/rear_caliper.jpg
Old Jul 11, 2004 | 08:25 PM
Camerone222's Avatar
I just put new brake pads on my car yesterday, and I had no problem with room at all. I could easily fit an air rachet in there to take both bolts off to remove the caliper. It was a very easy install and they are working great now.
Old Jul 11, 2004 | 09:00 PM
n2ceptor.Thanks, That will come in handy. Camerone222 There was no way I could get a ratchet to my bottom bolt tried every which way I could. I'll just have to try to take out the top bolt and swing down like some of the other members suggested. Thanks for all of the reply's.
Old Jul 12, 2004 | 07:17 AM
Jay-Roll's Avatar
You should have no problems at all getting to the bottom bolt. I got a ratchet in there just fine when I replaced mine a while back. Just took em off again when I swapped rear ends last week. I didn't remember having any H-shims though. What exactly do they do?
Old Jul 12, 2004 | 03:50 PM
What model is you car Jay-Roll? Does it have the parking brake unit bolted across the bottom bolt of the caliper?
Old Jul 12, 2004 | 05:51 PM
Jay-Roll's Avatar
Mine is a 95' Z. The parking brake part is located on the lower part of the caliper for me. With the round "hockey puck" style rubber peice attached to it. Since mine ceased up I took just about everything associated with the parking brake off except the handle. My car is A4 so no worries.
Old Jul 12, 2004 | 06:44 PM
"Mine is a 95' Z. The parking brake part is located on the lower part of the caliper for me. With the round "hockey puck" style rubber peice attached to it."
Yeah sounds pretty much like mine. But mine has a bracket that covers the bottom bolt of the caliper. I'll check again some time this weekend and make sure i can't get to the bolt some how, just in case.
Jazsun
Dec 29, 2014 12:14 PM
FredM
Dec 18, 2014 01:40 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
