Track Kill Stories Race Track Victories, 1/4 Mile Times, Dyno Numbers - DRIVE RESPONSIBLY
Just bought a 95 Z28
Old Jul 10, 2004 | 11:19 PM
TomH's Avatar
Hello,
I just bought a 95 Z28 convertible (only 70K on it!!).
Its a weekend toy, to have some fun with.
Anyway, its an auto, fully loaded. I am curious as to the 0-60
and 1/4 time for this AUTO Z28, it is totally stock.
Old Jul 10, 2004 | 11:51 PM
Steve Y's Avatar
Mid to low 14s in the 1/4 at 97ish and low 6s 0-60. Which gears does it have? Congrats on the new car and welcome to the board!
Old Jul 10, 2004 | 11:55 PM
TomH's Avatar
Good question on the gears, I am not sure.
How do I tell what gears it has in it?
I even have the window sticker and everything on this car.
The previous owner took really good care of it.
Take a look:
Old Jul 11, 2004 | 12:10 AM
TomH's Avatar
One other question I have. Since this car is totally stock and not
my daily driver. I am debating if I should keep it stock and hold onto it for many years (have a 2004 Acura TL) and this car won't see huge milage over the next 5 years.
Or should I put a cat-back system and K&N intake system onto it?
Just thinking that one day this particular car will be a classic and
not sure if messing with the exhaust will ruin that. I can put the K&N system in and save the original parts.
Will these two changes (cat back & K&N intake system) make a descent change in the performance of the car?
(My TL got smoked by what I believe was a 2003 AMG I am not sure but think it was a 500 series or 55 series, do they still make the 55 series?)
Later.
Old Jul 11, 2004 | 12:21 AM
Z28WannaB's Avatar
I think it would take a long time before that car would become a classic. By the time that car is classic we will probably not be using gasoline in cars :-P
I vote for HP.
- Z28 WannaB
Later.
Old Jul 11, 2004 | 09:34 AM
BiGGinZ's Avatar
To check the gears look at your shifting column if you have P-R-N-OD-D-2 Then you have 2.73's...if you have P-R-N-OD-D-2-1 Then you have 3.23's.
Old Jul 11, 2004 | 09:51 AM
Steve Y's Avatar
That will work if you are absolutley sure no one ever put gears in the car. You can also jack up the rear end, mark the drive shaft and one back tire and spin the rear tires. Count how many revolutions of driveshaft makes compared to the rear tire. If the driveshaft spins about 2.73 times for every revolution of the tire then you have 2.73's, etc.
Also check out this link. See how fast your car goes in 1st or 2nd gear tached out and compare to the chart.
http://www.f-body.org/gears/
If you have 2.73s the first mod to do is take the shifter column apart and cut off the black plastic cube with a hacksaw blade only, that limits the shifter travel to 1st gear. Then you will be able to put the car in 1st gear anytime you want.
I would mod the crap out of that car and sell the TL if it was me. Intake and exhaust, pulley, airfoil, etc. will really wake up that LT1. The TL and the Z28 are about the same in the 1/4 mile right?
Old Jul 11, 2004 | 11:35 AM
Steve Y's Avatar
Originally posted by robvas
Just stand on it from a dead stop. If you hit 35mph or so before it shifts into 2nd, you've got 3.23's, if it gets to 40-45 you've got 2.73's
Or just tell us what your RPM's are in drive (not overdrive) at say, 60mph)
Actually it will be about 44 mph at 5700 rpm in 1st gear with 3.23 gears or 52 mph at 5700 rpm in 1st gear with 2.73 gears. Try it and get back to us.
Old Jul 11, 2004 | 12:23 PM
camzaro28's Avatar
well i have 3.23 and i hit second gear at 37 mph. cruising at 75 in od im at 2500 rpm's.
but one more thing u can do is look at you rpo codes on your driver door.
Old Jul 11, 2004 | 07:16 PM
Antz97ZNJ's Avatar
good kill
Old Jul 11, 2004 | 08:25 PM
lovescamaros25's Avatar
i have 3.42s.
Old Jul 11, 2004 | 08:27 PM
how do you know where a camaro will shift with different gear ratios.you own a mustang,it would be different than a camaro.
Old Jul 12, 2004 | 08:00 AM
im curious is there an automotive calculation for finding your gear ratio based on speed divided by rpms,like there is with finding horspower.
Old Jul 12, 2004 | 09:37 AM
orbitalshock2k's Avatar
My first gear ends at 40 or a little above. Do I have 2.73s?
BTW Those 04' TLs are very nice. Keep it stock and it will keep it's value, you obviously have money, so mod the hell out of your Z and have a good time. I bought a 95' a month ago for a weekend car like you. Good stuff
Old Jul 12, 2004 | 10:06 AM
Steve Y's Avatar
