South Atlantic Delaware, Florida, Georgia, Maryland, North Carolina, South Carolina, Virginia, and West Virginia
is this a good buy???
Old Jul 9, 2004 | 12:14 PM
TheBeast_93LT1's Avatar
hey guys, i found this motor on-line. is it a good buy? will i need anything else for it to go into my 93' z-28? should i replace or upgrade anything else? your feedback is appreciated. thanks.
Here it is: $2295.00 + shipping
CHEVY 383/420HP STROKER ENGINES
THIS ENGINE HAS THE FOLLOWING:
Premium 4-Bolt main block.
GM 350/3.750 con rods with NEW Pioneer HP rod bolts and nuts.
NEW Eagle 383 Steel Crankshaft.
NEW Speed Pro Hyperutectic Flat-Top Pistons 9.5:1 comp ratio.
NEW Hastings Moly Piston Rings.
NEW Speed Pro Camshaft & Lifters .468/.480 - 220/231 specs.
NEW Fel-Pro Gaskets.
NEW Melling High Volume Oil Pump.
NEW Clevite Rod,Main & Cam Bearings.
NEW Pioneer Flex-Plate. GM Harmonic Balancer.
New Cloyes Double Roller Timing Set.
NEW Brass Freeze Plugs.
Premium MES Remanufactured Cylinder Heads with NEW 2.02/1.60 valves, Springs, Valve Guides, Locks & Seals. 76cc.
NEW Head Bolts, Pushrods & Rocker Arms.
MACHINE WORK
Bore and hone block with torque Plate with moly finish.
Deck cylinder block parallel to main line with CBN.
Re-size connecting rods with new bolts & nuts.
Hang and align pistons onto connecting rods.
Line hone main line.
Fully balance engine assembly.
Assemble.
ALL OF OUR ENGINES COME WITH A 5 YEAR / 50,000 MILE WARRANTY!!
Buy today and get screw-in studs, guide plates & hardened push rods!!
FREE!!
-Daniel
Old Jul 9, 2004 | 03:04 PM
4U 2 NV's Avatar
its ok i guess. you would have to beef the tranny up a bit. for that kinda money i would invest in a used LT4 kit. or see if you can get that motor but with higher CR and a bigger cam. that motor has lower CR and only a SLIGHTLY bigger cam than your LT1 stock.
Also, what about the intake? will your stock LT1 manifold bolt of to those heads? headers? tuning? there is alot to keep in mind when changing to a different motor.
Anybody else wanna help me with ideas here?
Old Jul 10, 2004 | 12:49 AM
2002Z28SSConv's Avatar
Again... what are you gonna do for spark? A 350 doesn't have an optispark and that distributor is gonna be hard to fit under the windshield.
Here's what you want to hear. It will fit perfect! You'll love it! It'll be fast as greased lightning!
Old Jul 10, 2004 | 01:47 AM
Soma07's Avatar
Do yourself and your car a big favor and just leave it alone.
Seriously, its painfully obvious you're in over your head. Just because you found a cheap 383 (cheap in more ways than one) in some catalog does not mean its a good idea to attempt to stick it in your car. I do mean attempt because thats a Gen I SBC and won't work in a 4th gen car without some serious work.
Old Jul 10, 2004 | 02:47 PM
S. Holley's Avatar
true true
true
Old Jul 10, 2004 | 05:33 PM
Camride's Avatar
HectorM52
Jun 23, 2016 08:42 PM
LastChance719
Cars Wanted
Feb 16, 2015 11:03 AM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
