94 wiring problem interior
Old Jul 8, 2004 | 09:24 PM
RMC's Avatar
RMC
I have a 94 Z28 and if you put the courtesy fuse #8 in, the time stays lit up on the radio and thus the battery drains.
If you open the door with the key off the radio itself turns off as normal but the time stays lit up still. Also, if you turn key off but don't open the door and wait then the 10 minute time delay thing works as it should but still the time stays lit up.
If I take the fuse out the radio turns off completely when the power is turned off but has no memory retention for the stations.
Anyone have a clue what this might be?
Old Jul 8, 2004 | 09:43 PM
Dave89IROC's Avatar
bad radio
Old Jul 8, 2004 | 09:57 PM
RMC's Avatar
RMC
Is that an experienced answer or more of a guess?
That's awesome if that's all it is.
Old Jul 8, 2004 | 10:01 PM
Lyle A's Avatar
That's all it can be. The radio has a short in it or something like that. The clock itself shouldn't drain the battery. You could have weak battery or alternator too.
Old Jul 8, 2004 | 10:17 PM
Dave89IROC's Avatar
It is a common problem with 80's early 90's GM radios, happens lots on third gens
Old Jul 9, 2004 | 09:24 AM
HBHRacing's Avatar
the only other thing I can sugest is the ilumination circut could be back feeding. the dimmer switch could be sticking I supose. I would check the brown and grey wires on the radio and see if they continue to get power.
Old Jul 10, 2004 | 08:49 AM
Same thing happened on my mom's old 94 Cavalier. Pretty sure it was the radio, but she traded the car before getting it fixed.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
InfernalVortex
Jan 17, 2015 09:35 AM
siguy
Nov 27, 2014 10:07 AM
